Whoa! That was a close one. Mark me safe from Honda strut bolts.Lots of Honda strut bolt are 24mm
Aka a 15/16".....................use both all the time on trucks.It's a very uncommon size for me. I was an auto tech for over a decade and I never touched a 24mm tool until I needed to replace the EGR tube on my Furd Ranger.
The rear drums on a '68 (?) VW I had were held on with 24mm castellated nut, IIRC. I kept the socket for 30 years when it turned out to be exactly the size for the oil filter cap on my 2004 BMW. So a common enough size for European cars, I guess.It's a very uncommon size for me. I was an auto tech for over a decade and I never touched a 24mm tool until I needed to replace the EGR tube on my Furd Ranger.
I haven't. Looks interesting.Have you guys seen this:
EARTHQUAKE XT 1/2 in. Composite Ultra-Torque Air Impact Wrench, Twin Hammer, 1500 ft. lbs.
I can't wait for the Torque Test Channel review of this, should be interesting.
Don't know I'm hoping TTC will do a YT review and I'll be able to determine whether or not to purchase.I haven't. Looks interesting.
Is it a pass or fail?
These will be great for gates. Or anything. https://www.harborfreight.com/combo-cable-bike-lock-66689.html
- $5
- Easy to set combo
- Good feel
- $5
Just so potential new neighbor kids or random utility worker doesn't leave a seldom used gate open. Locks are about keeping honest or mostly honest people that way, shitbags are a different matter and will have a way to easily defeat it.And about 5 seconds to defeat
/lockpickinglawyer probably
Big fail on this: Double Garage Magnetic Screen Door
Thin screen janky top mounting system and little velcro squares for the side closures are too far and few between, as well as no storage methodology.
I have actually been very happy with the ones I got long ago as free items. Funny you mention this because I have one at work today I plan to give to a coworker as a gift.Has anyone bought the electronic fly swatter from HF?
Great to hear. I actually bought this a while ago when it was on sale but haven't got around to using it yet. Does the moveable front portion work well or did you have a chance to test it?BIG PASS! This grinder shroud has been great.
Well built, plenty of adapter pieces for most grinders (mine a older Hitachi) and multiple hose attachments.
Excellent dust control, and makes grinding concrete a breeze.
7 in. Surface Grinding Dust Shroud
Amazing deals on this 7In. Universal Dust Shroud at Harbor Freight. Quality tools & low prices.www.harborfreight.com
Lol, good to hear.BIG PASS! This grinder shroud has been great.
Lol, good to hear.
I just found one of these unopened in a box of stuff, on my garage yesterday. Purchased it with the 13 amp grinder a while back and just used the grinder, for a different job.
I have some concrete resurfacing jobs coming up that to put it to use.
I did about 15 years ago...I had to shave my balls to make contact though.Has anyone bought the electronic fly swatter from HF?
My parents took a bunch back to the UK many years ago. Step dad trapped a fly between the swatter & a window at my place one day so pressed the other side with his finger... *ZAPPPP!!!* He was quite impressed with it's efficiency, in fact I think the neighbors heard his product endorsement.Has anyone bought the electronic fly swatter from HF?
I'm surprise. I bought a Master Cool set and they were identical to HF set.Fail: Pittsburgh R134A A/C Manifold Gauge Set.
I purchased this out of desperation, after the USPS decided not to deliver my Yellow Jacket gauge set on time and has it held up in shipping...
I was able to successfully pull and hold vacuum with this set but it failed when I tried to charge my AC. While charging my AC, the High Side line started to leak where the fitting from the gauge physically attaches to the high side hose. Because of that, I had to close off the valve on the quick connect fitting and detach it from the system and I was unable to read my high side pressures.
I tried to quickly remedy the problem by attempting to attach my high pressure line from my old Mastercool set that has a faulty gauge, but the threads were smaller on the HF manifold set.
I'm bringing it back today and requesting a refund. I know this thing has worked for several others but I cannot recommend after my experience yesterday.
Which vac pump do you have? Is it still made?I had a R134A HF gauge set from a few years ago. It worked a couple times and then suddenly failed. I don’t remember the specific failure point now. I replaced it with an all brass set. Can’t recommend the HF tool.
I do have a HF vacuum pump for HVAC and it’s been working great
I have one of their pumps and it has worked well. Too bad the same can't be said about the manifold gauges. If the high pressure line wouldn't have failed where the fitting met the line, I would have kept it as a backup unit.I had a R134A HF gauge set from a few years ago. It worked a couple times and then suddenly failed. I don’t remember the specific failure point now. I replaced it with an all brass set. Can’t recommend the HF tool.
My MasterCool set is an older USA made set with the sight glass in it. It was working fine for the last 8 years but now the Low Pressure gauge is not working. I believe after all of the use over the years, it probably got knocked around and now the gauge doesn't read properly. After my new set comes in, I'll probably purchase a new gauge for the low pressure side of the MC unit and keep it as a backup.I'm surprise. I bought a Master Cool set and they were identical to HF set.
Looks like the Astro ThorHave you guys seen this:
