Seems quite loud.
Thinking about it, but in the warmth is better. I used to have a 60 gallon out in my shed, it would trip the breaker when it was -20*Videos, especially cell, phone videos can be quite misleading.
I am not finding a 12-50 but 12-40(60decibles)or a 18-40(50decibles).
60 decibels is a normal conversation, 50 moderate rain fall.
Cal air tools, another common brand has a 60 decibel rating for those continuous industrial models.
Build a cooled and insulated cabinet for the compressor or put it outside if that is to loud.
Jun-Air is a brand. They offer many oil lubed and oil free compressors. That said, I think what many people think about when they see/hear Jun-Air are their small, oil-lubed compressors which are indeed, very quiet. That said, they have pretty low output and are outrageously expensive.I believe Jun-Air are based on refrigeration type compressors. I don't think you will find something that is quieter. CAT and similar brands may be quiet enough but if this is something that you expect to last for many years I would feel better about a Jun-Air than a oil free CAT compressor.
Again enclose it and insulate. Just make the air circulation so it can be blocked off on the winter and place an 120v oil pan heater on it.Thinking about it, but in the warmth is better. I used to have a 60 gallon out in my shed, it would trip the breaker when it was -20*
That'd be expensive to run. Even a small 500w one would be $70 a month, which is more than my usual bill.Again enclose it and insulate. Just make the air circulation so it can be blocked off on the winter and place an 120v oil pan heater on it.
500 w heater is gargantuan for a pump on and air compressor, especially one in an insulated enclosure as the pump running is going to make some heat. And the insulation retains it. A 25 watt heater would be sufficient.That'd be expensive to run. Even a small 500w one would be $70 a month, which is more than my usual bill.
Sure did...The OP didn't say how much air they need or how much they are willing to spend, so we probably need a little more info to work with.
Sorry, I swear I checked and I saw the 70 psi but didn't see the flow specified.Sure did...
"can handle ~70psi and maybe 5cfm."
It's what blasts the oil into the burn chamber.Wow, thats a lot more air and much higher pressure than I would have guessed.
Any way to do it with a blower or is 70psi critical?
Anyhow, can we assume you don't want to spend $5,000+ on a Jun-Air? If not, there are lots of little oilless compressors that will make around 5 cfm that are rated at or under 70 db. On the cheaper end is this harbor freight fortress compressor. There's a coupon for $40 off right now making it even cheaper.
As ching mentioned above, there are several California Air Tools 2HP models that will make 5cfm for between $400 and $500, depending on the tank size/material you want.
Is this quiet enough?
Haha, that's a whole different thread topic!Sort of looking at a scroll compressor.
Haven't decided if I want to do a little compressor for the boiler and the loud piston compressor I already have for shop air or a scroll for everything.
Around $3000 to my door, so not cheap.
When the boiler is running, so 10-12hrs a day when it's cold.Does this thing need 5 cfm continuously? I mean that would likely need 1000W continuously or $1000+ of electricity per year.
Wow. That's going to be expensive to run but guessing cheaper overall than something like propane.When the boiler is running, so 10-12hrs a day when it's cold.
Yeah, I don't know if any of the above will like 100% duty cycle. Some of those twin cylinder belt driven ones can be fairly quiet and likely OK for continuous being oil filled.Does this thing need 5 cfm continuously? I mean that would likely need 1000W continuously or $1000+ of electricity per year.
If you look at the manual for the emax you can see how the muffler box is made. Nothing special other than they actually did it. A DIY option wouldn't be hard for someone who can cobble together a plywood box. The lower RPM does help but I think the biggest impact is simply creating what amounts to an intake muffler. Most compressors just don't bother.Yeah, I don't know if any of the above will like 100% duty cycle. Some of those twin cylinder belt driven ones can be fairly quiet and likely OK for continuous being oil filled.
This thing's just got a muffler attached to it
looks like the ticket is bigger "low rpm pump" and muffler:
5 HP Air Compressors Archives
5 HP Air Compressors. Eaton Compressor carries a wide variety of rotary screw and piston air compressors with the best warranty in the business.eatoncompressor.com
claims 62db:
yup. I do think reducing RPM while oversizing the pump in order to hit your CFM target is also a good strategy. HF has a 1k rpm pump head so makes me wonderIf you look at the manual for the emax you can see how the muffler box is made. Nothing special other than they actually did it. A DIY option wouldn't be hard for someone who can cobble together a plywood box. The lower RPM does help but I think the biggest impact is simply creating what amounts to an intake muffler. Most compressors just don't bother.
That's what I was going to recommend if you want something quiet.Sort of looking at a scroll compressor.
No suggestions on a compressor and excuse my ignorance on waste oil burners.It's what blasts the oil into the burn chamber.
Dunno, they don't work like that to my knowledge.No suggestions on a compressor and excuse my ignorance on waste oil burners.
Why can't you use a liquid pump to pressurize the oil and atomize through a nozzle like a typical burner?
I believe waste oil needs a lot more air than just ambient in order to get any real heat.No suggestions on a compressor and excuse my ignorance on waste oil burners.
