How do you store you weedeater \ trimmers
jashgtp
Florida
Well, just picked up a Stihl FS 55 R :bounce:
And wanted to see how everyone is storing them in the garage.
Also, engine up or down?
This is a summer heavy use storage not winter storage.
Thanks
csp
Franktown, CO
I also have an FS55R. Stored with the engine up leads to leaks of fuel/oil mix on the floor, so I'm interested to see if there are any unique ideas in this thread.
ledthrax
Yardley, PA
I also have the FS 55R (great trimmer by the way) and always store it laying down, either on the floor or on some hooks on the wall.
J
jashgtp
Florida
csp where was it leaking at?
Floor space is a premium in my garage so i have to hand things vertically mostly.
Or i could to vertically up on the wall with two hooks possibly?? hmm
Jononon
My father's is hung from its guard onto a grab rail screwed to the wall, engine down. No leaks, in fact that's how they're displayed at the dealer.
beelsr
NE PA, USA
get one of those bent aluminum tubing hooks that screw into the wall and hang it up on that. if you look at the engine end, you'll see where the case is designed to hang.
if you're hanging it up and have a fuel leak, well.... you have a fuel leak. And you should fix it....
Rando
Oceanside Ca
[QUOTE fact that's how they're displayed at the dealer.[/QUOTE]
But there's no fuel in them at the dealer. I always heard horizontal for storing them
srmofo
SW ohio
Ive got a fs110 and it just stays on the cheap trimmer rack on the trailer. I say cheap because its just made of steel channel and square with some hitch pins to keep it from falling out. The balance on the trimmer causes it to roll upside down. I never have fuel leaks.
If I rememebr right, the fs55 has a curved shaft so if it was on a trimmer rack it would probably stay upright.
Just google trimmer rack and you will be amazed at how many different types there are. And Im sure one of racks for an enclosed trailer would work for you, or at least give you the blueprint for your next project.
Jay H 237
Torrington, CT
Both trimmers are stored vertically hanging on the garage wall to maximize space, an electric Weedeater and a gas Shindawa T-18. The gas one is stored engine down. The only fuel leak was a few years ago and replacing the dried out cork gas cap gasket fixed it. It has been stored full of fuel and hasn't leaked.
z28snksknr
Turnersville, NJ
I hang it on the wall, just like everything else!!!
otis66
You should never store your weed wacker or any type of lawn equipment with the gas in the tank. It's bad for the carb and you will have problems starting. If there is no gas in the tank you can store the equipment any way you like.
Ram
Virginia
Just lie mine down on a shelf in the shed horizontally.
Only thing that I do to preserve the fuel mix is always run a true synthetic lube oil mixed in the gas and tank full.
Next season prime bulb, click open throttle normally starts on second rip of cord.
nate379
Palmer, AK
I just throw it in the woods when I'm done. Neighbor comes and grabs it when he needs to borrow it. Just a 5-6 year old $50 job so I don't care about it.
bushhawg73
Columbia, Missouri
I hang my echo pole saw and weedeater horizontally on hangers I bought at tractor supply for a couple of bucks. I also second the idea of no gas in the carb. If mine are going to sit for more than a few days I drain the tank. This is what has worked for me. I used to leave fuel in them and after a few carb rebuilds I stopped.
:beer:
e-tek
Saskatoon, SK
I swadlle mine in fine micro-fibre trimmer-jammies and gently place it in a trimmer-manger. It's made of the finest natural fibresin order to keep all surfaces properly craddled......
Ya Right!!
GTVi
Australia
I hang it up horizontally, but I also empty out and run off the remaining fuel each time...
T1320T
Indiana
I hang my Echo vertically w the engine up... no leaks. It starts easy during the summer & takes about 3 pulls in the spring. I always mean to drain the tank at the end of season but it somehow never happens.
GTO
NJ,FL
I don't store any of that **** in my garage.It lives out in the shed with the rest of the lawn tools. I suppose it's just laying on the floor in there somewhere.
csp
Franktown, CO
Perhaps you should define your idea of "store". I leave gas in mine during the lawn season. I'm not going to drain the tank or run it dry after the weekly (sometimes more than once a week) mowing/trimming.
Between mowing/trimming they still have to be stored somewhere so nobody is tripping over them, even if it is in a shed.
T1320T
Indiana
I don't store any of my lawn related **** in my car garage... they go out back in their own garage.. away from anything important that they could fall on & dent or scratch.
baucom
My Shindaiwa trimmer hangs horizontally from 2 rubber coated hooks screwed into the wall studs of my shed. No leaks so far. Every winter I dump the gas and run it dry, but it's always stored with about 1/2 tank during mowing season.
BlindViper
York, PA
I use one of those hooks you screw into the ceiling joists. I hang it from the handle on the ceiling. I am 6'4" so I hang a lot of things from the ceiling.
babzog
Eastern Ontario, Canada
Used the "fork" bracket for the track system I picked up at CT Boutique a couple of years ago. Works well. Before, I used to hang it from the trusses in the shop by the business end. Never had fuel spill in either orientation.
J
jashgtp
Florida
that hook from lowes looks like it will work perfectly. Thanks
too bad my local one doesn't have any..off to try Home Depot or Menards
MightyBouch
I have two areas (a fully enclosed shed and a pole barn) where I keep my yard equipment. During the summer I keep everything in the pole barn like so...
The reason being simply for ease of access. During the winter months I keep them in the shed. Before stowing, I get them ready for long storage. Here is a guide for stowing Stihl equipment — https://m.stihlusa.com/information/how-to-guides/outdoor-power-tool-extended-storage-tips/ — I usually do this b/c my weed eater, chainsaw, & gas blower are all made by Stihl so I figure they probably know best. :) :rocker:
bobcatdan
Kaukauna,WI
Horizontal on a shelf in the garage. The shelf was there when I bought the house and looked like a good spot. At the old house, hung it engine up. Never leaked and always started first pull.
Michael_in_DE
Wilmington, DE
Horizontally in somewhat climate controlled garage.
Got tired of buying used every year and it lasting only 1 year, (sometimes less!). Bought a new Echo, and I'm trying to treat it as gingerly as I can, right down to buying the over-priced Echo Gas. I want it to last, and I don't want to hear anything from Echo if it has to go in for repairs. After so many trimmers and as hard as they seem to be to start for me, if this one doesn't last, I'll just go electric. Which I have had to do with the blower.
driftpin
I have vinyl-coated wire shelving in the tool storage area, and I use bungee cords to suspend it below one of the upper shelves, above 6 ft. It's level, I don't use the fabric-covered many-strand bungees, but the thick, solid-rubber ones, One hook on the wire rack, the strap underneath the tube in-front of the engine, and another about a foot from the string head. I ensure it's sitting level, because if you're careless, you could hang it with the gas cap lower, and fluid can weep out either the vented cap or the fuel-return hose.
