Electric fence
RalphInCA
Wine Country, OR
I’ll admit it: I grew up in the suburbs. I have zero idea about, but an incredible amount of respect for, farm life.
For some of you this will be an incredibly stupid question.
Recently moved into a house that backs up on a farm. Farm has an electric fence.
How can I determine if the electric fence is on without touching it or otherwise, doing my self harm?
zendriver
Indiana
Touching with the end holding a long blade of grass. If it’s on, you’ll feel a slight pulsing tingle.
duneslider
Riverton, Utah
Just touch it...or get your kids to touch it. My in-laws neighbors both have electric wire and its our regular game to have the kids touch the fence. Or link hands and get the whole family involved.
My son and I can touch them with little to no effect but then when we touch someone else we all get zapped. Always good times with the electric fences.
Why do you care if it is on or not?
BrandonV
Arizona
Tester is only $20 or so. If you have a fluorescent tube laying around you can use that too.
PoorUB
Fargo, ND
Shove a steel stake into the ground with a wire attached to it, then touch the wire to the electric fence. The wire will have less resistance than your body and the voltage will flow through the wire easier than you. You wil see an arc like a spark plug tester. You could add an insulated handle to be more certain.
One question. I assume the fence is not on your property, so why the concern? You shouldn't be messing with it.
kmacht
Connecticut
Are you sure it’s an electric fence? There are many high tensile and coated wire fences that look like they are an electric fence but are not. There should also be an energizing box somewhere along the fence that the wire runs into. If you can see the box you can see if it’s turned on or not. If it were me I would go knock on the farmers door and just ask him. You will find that most farmers will be much more receptive if you just go introduce yourself and ask instead of them finding you poking around on their property trying to find out the answer yourself.
jonesg
northern Maine/
the Maine farmer next door to me would say why don't ya touch and find out.
mbutler
Either look for the energizer and see if it is pulsing or touch the wire (gingerly) with the back of your hand. If the fence is live, using the back of your hand will cause your muscles to contract and pull your hand away from the fence. Note that the energizers usually pulse once per second.
R
RalphInCA
Wine Country, OR
Because there is a location near my neighborhood that I’d like to get to that follows the path right next to this fence. I just wanted to know what would happen if I accidentally grazed the fence while it was active.
Plus, I’m simply curious.
PoorUB
Fargo, ND
Yeah, I know — I won’t be messing with it. It’s not mine to mess with.
But it is on my border, so I would like to know what’s going on.
Just assume it is live and don't worry about it. If you have kids they will try it out, once, then never go near it. It won't hurt them, but it will teach them not to F with it.
Citation
Indy
I grew up with tension wire fences. Some are, some aren't energized. One way to tell is if the wire doesn't have an insulator where it touches the pole it's not energized. The other way you can check is just slap the back of your hand on it. The idea is to move quickly so even if it is on you only get the jolt for a moment (it's not fun but not that bad). You do not want to grab your hand around the wire as you won't let go until the power cycles (and they do cycle).
Squez
Southern California
Man up and Grab it.. when I was forced to put a electric fence for my dog I put in one for cattle. My dog was 120 pounds . so after install I decided I would grab it before I pushed my dog into it.. didn’t feel right about him getting hit before me.. it’s not that bad but it will keep the dog away.
Snip
Crossville, Tennessee
We have been on our property a little over 3 years. The farmer next door ( best neighbors a guy could ask for) has a good sized Apple orchard on my north side but also runs cattle below me. Fenced pasture with a single strand barb wire and a single hot wire on his side a bout 6" down. We shoot the breeze over the fence regularly. Twice now as I am resting an arm on the BW my hand will get "lazy" and droop to the hot wire for a second, and only a second, lol. I'm a good learner, just not a fast one, lol. He gets a good laugh and thanks me for testing the fence. When I'm not available to "test" I have seen him test by holding a wooden handle hammer and push the hot wire close enough to the metal fence to get an arc.
mrb1
Miami County, Ohio
Fishing in the creek as a young 'un, straddled a hot fence while standing in the water once. Almost made it, left a good welt on my inner thigh. Good thing the boys hadn't dropped yet, or I really would have been hurtin'.
alfadan
Augusta, ks
Is there any tall, green-ish grass growing into it you can get to? You can usually hear the pops going to ground through the grass, especially on a dewy morning. But as mentioned, no yellow insultors or fiberglass posts, no electric.
zendriver
Indiana
It's pulsed electrical output, maybe about 7,000 volts, but only about 100mA of current. Touching the wire while standing on ground completes the circuit, while the current flow goes through your body, which you will feel. No biggie unless you maybe have a pacemaker or very weak heart. :dunno:
Animals usually touch it once, and get the message.
WillyBoy
Genesee valley area of New York state
Here's another take on it. How many farms or other agricultural facilities switch the fence chargers off on a regular basis.
It seems to me that it's not like turning off a light when you leave a room. My guess would be that the chargers are on 24/7.
Figure on that and act accordingly.
JeepYJ
Depends on how you fence or graze your animals. I rotational graze some cows. If they’re out in that area the fence is on. If they’re not it’s off and another section is on.
Either way, if you accidentally get shocked it’s not going to kill you. It’s more surprising than anything.
