Floor Jacks: Revisited
BigE
Central Alabama
I read through the other floor jack threads and it seems the general consensus is to rebuild an old one. Well, after perusing local ads, local sites and fleabay, used does not appear to be an option for me. Looking at Northern Tool, some of the prices and product quality seem very attractive. Here's the situation. I have a small two car garage with a flat, finished (but uncoated) concrete floor. The driveway outside is typical driveway concrete texture and is almost perfectly flat. However, there is a 1-2 inch transition from garage to driveway where the driveway settled. I like to do my wrenching in the garage but necessity has dictated a lot of outside work lately so the jack needs to be capable of such. I have a truck and a sports car. I'm mainly concerned about the car. The jack I was using (neighbor who moved away) was the black Craftsman quick pump 3 ton. It was too tall by about 1/2 inch to get under the crossmember of the car. However, I still need to be able to get the truck off the ground for brake work, etc. I'd like something no lower rated than 3 ton. A "want" more than a "need" is lightweight. I have loaded up jack and stands to go help stranded or non-mechanically-inclined friends so lower weight would help. I'm looking to spend good money for a good quality jack that can be rebuilt years down the road. I'm not spending $500, though. With all that said, what are your thoughts/recommendations?
P.S. In my research, I found this site (http://www.hyjacks.com). Just thought I'd pass it along for consideration and criticism.
Hiball
Missery
BigE, Picking the correct jack is based on numerous things. Ill touch on a few here and try and get you going in the right direction. First off.. What you actually need? This is very important because regardless of how much something costs, if it doesnt fit your needs its a waste of money. So lets find out what type of vehicles you will be lifting, This will give us tonnage requirements . I read from your post that you would like to have a minimum of 3 ton, So what kind of truck do you have? and in regards to your car what is the minimal working height to get to Lifting point? Secondly what is your price point? You ask for Rebuildable down the road, 6 years ago i would say every jack ever made was rebuildable, Today every Jack manufactured has replacement seals available thru 1 source or another. Whats the difference? And im running into this more often this year than i can remember previously. Todays Import jacks "Do not" like to be taken apart, Plain and simple. The metal is not as strong, The machining doesnt fit as good as it should and The Threads are very.. very.. BAD. I cant tell you how many times ive run into issues on jack Tank nuts being cracked, Piston chrome sleeves "Wearing" to the point where it eats up the seals etc.. etc.. etc... It makes sense from a Consumer standpoint if you stand back and look at the sitsuation, Regardless of how many Orange 2 ton jacks a company produces and sells at HF for $49 there still has to be shortcuts to get there. Im not bashing anyones views, Its Cut and Dry the NEWER IMports are not designed to be rebuildable, I have first hand views and have seen the changeover in the Craft. The original Manufacturer didnt fathom anyone would even think about the possibility that someone would want to rebuild there HF jack. So i hope you see my dilema on how difficult it is to point you in the right direction, There will be some here that say the Costco 3 ton jack is the best jack in the world etc.. etc... But if you read the reviews you will see there are problems, It has Fluttering Valve issues and again if you stick around those problems will begin to magnify over the next year i suspect for previous owners. Again, I praise the higher end jacks, and i understand that they are pricey. I also have a firm understanding of what Makes a Floor jack Great, Im not trying to sell you anything. Im offering my time to help you make a good choice, Im not gonna blow smoke up your AZZ and tell you that a $50 dollar jack will last you 10 years, it wont happen with todays Cheaped out seals (check my Import Rebuild) There will be some that have had Good luck with these jacks but i promise you there are MORE who have had issues. (taddwholesale from Ebay) So you get me some information (Min required Height and Budget) and ill see if i can point you in the right direction. Also where are you located?
CRTDI
Sounds like you want your cake and you want to eat it too. In the current new jack market this goal is nearly unobtainable. There are certain tools where it pays to be cheap. In the interest of your personal safety, a floor jack is not one of them. Look for the best quality jack that you can afford.
If you're really looking for good value and a well built product, exercise a bit of patience and continue to look for an older quality U.S. unit in good working order. My preferences would be a Walker, Weaver, Lincoln, Hein Werner, Milwaukee or Blackhawk.
If you don't go the used route, IMHO, these are the only new jacks that you should even consider:
1) http://www.milwaukeehydraulic.com/products.html
2) http://www.acjacks.com/index.html
3) http://www.castleequipment.com/Jacks/service_jacks_by_weaver.htm
4) http://www.shinnfuamerica.com/ProductCategory/Hein-Werner_Automotive/Service_Jacks/99
It's going to be a crapshoot with any of the jacks you can buy at HF, Sears, Costco, Sams Club or home center type stores and automotive parts stores. Depending on how you use them, they might work just fine. Most will not be rebuildable, and don't even expect to get a life's time of use out of them.
BigE
Central Alabama
Hiball,
Thanks for the detailed response. My current vehicles are a 2002 Firebird Formula and a 2000 Ford Ranger Supercab. However, the Ranger is not long for my driveway. As soon as possible, it will be replaced by a Tahoe or full size 4 door GM truck. Keeping an eye to the future, I'd like to purchase a jack to use for years/decades to come. So I'd like it to be able to lift any vehicle I may purchase within reason (I don't expect it to lift a Jeep on 35's or a military deuce & 1/2 project). As for price point, I'd be comfortable spending up to $350. I'd like to spend less and I'd like to be able to spend more, but that's the reality of my current situation. All I've really used my whole life have been Craftsman jacks. Dad had two when I was growing up and the neighbor's quick lift CM I mentioned so I'm sure anything over $150 would be an improvement. Addressing your last two questions, I'd love to provide a minimum height measurement to you, but at the moment, I'm only a stone's throw away from you in Columbia, MO on business. When I get home to Birmingham, AL, I'll get that measurement for you.
Additionally, I read your entire import rebuild writeup thread. Great information there. Dad's older CM jack is in need of a rebuild. It's too small for what I want long term, but rebuilding it may buy me some time to find a good quality jack of appropriate size. Heck, it may just be fun.
Indy_500
Appleton, WI
This may be a stupid question as i have never had a floor jack before but are there any jacks out there with a lifetime warranty? seems like they should offer that.
Hiball
Missery
I do believe the HW93642 is a great choice, Its only a 2 ton jack but.... it will handle a Full Size Pickup or Yukon with Ease. You need to remember your only lifting a portion of the vehicle at a time. Here is a Link to one of the cheapest places i found while googling. http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=HEIHW93642&source=froogle&kw=HEIHW93642 I expect if you do some more research you can find some places that maybe offer Free shipping or i know Sears offers these jacks thru there website. IF you really want a 3 ton they do make it and its a HW93652 but its priced a bit higher. These are great jacks and will provide its owner with Many Years of reliable service, To boot there cheap and easy to rebuild.
Steven
BigE
Central Alabama
I measured the car and the distance between a flat floor and the bottom of the crossmember is 4.75 inches. So the stowed height of the jack pad must be less than that. Beyond the requirements already mentioned, my expectations are these. The valving/action will be linear and positive. The metal/structure will be solid with no distortion under any load. The jack will roll and swivel with ease across even marginally flat floors.
I like the Milwaukee jack that was posted, but there are no prices on their site even though it says you can order from them.
Thanks again, everyone!
MrMark
Southern Cal.
Seems like this classic jack; might fit the bill... I don't know about it going under your firebird, however...
Hein-Werner Service Jack – 2-Ton, Model## HW93642
http://www.google.com/products?clie...esult_group&ct=title&resnum=3&ved=0CDYQrQQwAg
This is the one I have. In my research, it was the best available on the market for the money. It should last a lifetime. The Milwaukee was the only other option I considered. The AC jack is too expensive now. Like someone said, a jack is not a place to cheap out. 300 for a jack is a good investment.
It's US made and it is a timeless design.
CRTDI
Yes, they advertise as made in the US. I wonder it they are built with all US components, some US components or just assembled in the U.S. from imported components? :headscrat
The company that makes this jack is Taiwan headquartered with facilities in other places as well as the US.
Shinn Fu Corporation Headquarters
7F., NO.408 Ruei Guang Road Nei Hu District Taipei City 114 Taiwan R.O.C.
Tel: 886.2.87517888
Fax: 886.2.87517999
Email: [email protected]
http://www.shinnfu.com/
MrMark
Southern Cal.
Tel: 886.2.87517888
Fax: 886.2.87517999
I did speak to customer service on the phone and they were adamant that they were made here. I was told the components were made here as well. Who knows anymore, though.
I had a guy the other day tell me that Snap-on tool boxes are made in China and that Snap-on lies about COO. Says he has seen Snap-on boxes made by the Chinese. There is not a whiff of this anywhere I have ever seen but this guy swears its true.
Hiball
Missery
Tel: 886.2.87517888
Fax: 886.2.87517999
There still 100% made in the states, including the parts. I just talked to the Kc plant last week and i deal with them on a regular basis. What's great about there design is that parts off jacks 70 years old will work on the new ones and vice versa. I wish they were owned by a American company but sadly shinn Fu takes there cut first.
anodyne33
Pittsburgh or there abouts
Is anybody familiar with a jack made by Auto Specialties MFG from Michigan? There's one on CL local to me for cheap, and my parts store special (MVP ProLift, ~10 years old) is starting to give up the ghost.
Flash21
Hiball - On the Hein Werner, what kind of vehicles would you have to be lifting for you to recommend the 3 Ton unit over the 2 Ton unit? I usually come from the school of more lifting power the better but I'm not sure if the extra $$$ is worth it to get the 3 Ton.
I would almost rather take that extra money and buy a 2nd unit because I have worked on things where I needed two jacks at the same time.
Hiball
Missery
If someone was working around 3/4 and up trucks all day long, I would recomend the 3 ton model. It offers a bit more lift (aprox 3 ") which comes in handly when your vehicle is a bit taller than your typical pickup. There is nothing wrong with More lifting power, except when your trying to use your jack for multiple vehicles that include cars etc, Account they generally have higher mininum height. In this case theres only 1/2 difference between the 2 and 3 ton (4 1/2" versus 5") so its not really to noticible. Its all personal preference, I really dont push the 3 ton model much as i would rather see someone that is gonna be lifting any tonnage at all use the 93657 which gives you 8000lbs of lifting, Length to get further under the load and a bigger footprint.
Hiball
Missery
Judging by the model number, handle assembly im gonna agree its a Ausco. I believe it uses a Ausco Hydraulic unit instead of the later Hein Werner units as i dont see a cross pin in front of the Rear wheels.... But the picture isnt the greatest.
BigE
Central Alabama
Hiball,
Given the height below and my budget of $350, what would you recommend?
Thanks!
Hiball
Missery
Hiball,
Thanks!
HW93642 (2 ton) which has a 4 1/2" min height, Which is just under your requirements i believe.
Steven
Sick Puppy
Sydney
Re: Floor Jacks- So, what about New Zealand?
Hey Hiball, dunno if you got my PM a few weeks back, but my problem is one of geography.
In NZ, most jacks are Chaiwanese- I don't recall seeing any US, Australian or UK built jacks here, so my options are fairly limited- I'm looking for older jacks from these places (wish me luck), but in the event of having to go for new ones (likely), any suggestions as to what to go for? Notable makes here are Torin and Wayco, and others like Ampro, Powerbuilt, and a few I know nothing about, like Cheftian
I'm looking for a jacks to use for cars up to the weight of a BMW 5-series or an SUV like a Toyota Surf. Minimum clearance would be 100mm. I would generally use with axle stands to lift front of car or all four corners for project. Budget would be around $200US (About $275), not that I'm asking you to look on NZ websites, but have you heard of any of the above makes? Any help, advice, suggestions etc would be much appreciated. Cheers!
Hiball
Missery
I wish i could be of more assistance but im drawing a blank on those brand names outside of Torin, Ampro and Powerbuilt and Those are Import Brand companies. I dont see any Problems that a 2 ton jack wont handle in regards to your vehicles, Maybe some of the Overseas guys can give you some more info on the other brands. There is nothing wrong with a Import jack, Ive sold many Omega branded jacks in my day and owned a few also. They are fairly solid jacks and on the high end in regards to quality of the fitment of parts etc... The lower end stuff is Hit or miss so i always try and push someone into a company that will stand behind there product with the best possible warranty. Hope this helps..
Steven
Sick Puppy
Sydney
(helpful stuff here :)
Steven
Thanks Hiball/ Steven, much appreciated- I figured they're import companies, but it's nice to know some of them are known overseas. Ampro here is at the lower end of the brand market, on a par with powerbuilt. Wayco and Torin are known for professional garage equipment, jacks and stands etc.
I'll have a look around for the Torin and Wayco ones as I've a few contacts with their stockists here, and I'll keep on looking for a few older US-built ones that I can restore. Let's see what I can rustle up for Christmas! :thumbup:
...rohit
I bought this jack a few weeks ago
I bought it used for $30 though, its been pretty good so far, much better than my craftsman
Hiball
Missery
I hate those retarded handles, Why they didnt allow the handle to park past 60 degrees ill never know.
BigE
Central Alabama
Steven
Thanks, Hiball! That is the one that I ended up with. It's heavy! I assembled it, but I haven't had a chance to try it out. The owner's manual said to pull the air vent, pump the handle 6-8 times and then check the level. The way it reads, you're supposed to do this every use rather than just before first use. It looks like it will fit under the car. I'm looking forward to finding out!
Hiball
Missery
You only have to do that after its been moved in such a way that would allow Air into the Valve system, ( ie:shipping, Moving it to buddies house etc..) Essentially all your doing is flushing the Valve system of any air prior to Pumping it into the Cylinder.
BigE
Central Alabama
I got around to checking it the other day and it's way low. The oil doesn't even cover the cylinder. I guess that's what was leaking out of it when I picked it up! :D I haven't used it yet so no damage done. I'll have to pick up some oil for it. HW suggests their oil, but there's probably not many places in town that stock it. Maybe I can get downtown to pick some up.
Larry M
Waldwick, NJ
That should work for the OP
I have a lowered 2002 Trans Am and while it is very tight I still get my Craftsman jack under it. Worst case I slide a low profile jack to bring it up an inch and then the big jack to get the car up
stonewellmark
Hudson Valley, N.Y.
Go to your nearest NAPA store they usually have a 3.5 ton jack on sale for 300, its made in china but re-buildable thru NAPA (they can get the kits). I got one and its great, I also got a rebuild kit after I bought it so I had one in case they changed suppliers down the road.
db130
Massachusetts
OTC 1532 aluminum racing jack: http://www.otctools.com/products/2_ton_capacity_aluminum_racing_jack
it's a reputable brand, it has good reviews online, and tooltopia(an amazon 3rd party vendor has for $232.99+$7.99 for shipping) and if you google for it, you can find a promo code to have the shipping charge waived. alternatively, if you buy directly from tooltopia.com, it's free shipping.
i have a made in japan craftsman 3-ton steel jack that was probably purchased back in the mid 80s that is still going strong and i was looking for something portable.
airbuff101
I'm pretty new here....and not real smart/easily confused :).... but whats the situation with AC jacks? The home page says they finally got some back in stock after 2 years yet all the floor jacks seem to be "unavailable at this time" or some such.
Is this the only distributor? or importer?
I haven't followed any info that may have been posted on them in the past. I thought maybe with the dollar down it might not be optimum importing euro stuff right now.
I'm just wondering because I am not familiar with that jack brand.
Rob
Hiball
Missery
Hmm.... buy a $300 dollar Import made by Shinn Fu or a $300 dollar American Manufactured Hein Werner that is Rebuildable and Time tested with over 70 Years worth of History. Id be willing to bet the 2 ton has a the same Cylinder size as the 3.5 ton... Its Funny How Consumers Go Gaga for Manipulated Numbers. How much did the Rebuild Kit Cost? Do you have a Model number or could i get the Local Number for your Napa? I have requests for these kits fairly often and i have to piece mine together from different distributors for Shop Repair. I wasnt aware Napa handled Kits after they quit selling Lincoln made Jacks.
stricht8
I was thinking the same thing. Why on earth would anybody spend $300 on a China jack?
airbuff101
my sentiments...precisely.
Rob
simplec6
I am also on a search for a nice 2 ton jack. There has been many threads on this forum and others, and it seems that there really is no consensus on one particular company or jack that is the best bang for the buck.
GeorgiaHybrid
Extreme NW Georgia
You need to read this thread carefully again. If you want a Chinese, throw away jack, go just about anywhere and pay $50 to $300 for one.
If you want a good, American made, rebuildable quality jack for not a lot of money, buy a Hein-Werner Service Jack – 2-Ton, Model## HW93642.
They are the same as the old Lincoln and Walker 93642 jacks.
If you want to pay for a top notch, American made jack, buy a Milwaukee model 20 or model 40 floor jack.
You can also buy a used Weaver, Walker, HW, Blackjack or Milwaukee and either have it rebuilt or re-build it your self and have a great jack at a lower cost. The older Matco, Snap-on jacks can be great also as many of them are rebadged Lincolns, Walkers, etc.
stonewellmark
Hudson Valley, N.Y.
Hiballs, the jack Model#:791-6420; complete seal kit#:rs35sk; and the release assembly#:rs3527. Their ya go a chinese jack from NAPA that can be serviced. Oh and my local NAPA number is (845)255-9190 and ask for Paul....:)
