Shows how much error can be in these sorts of tests. Willing to bet the regular Snap On bits are made to a much higher quality standard, but a single one does not represent it properly especially if it is faulty.Snap On’s came with soft bit
I like the Vessel TD-800 / stubby ratcheting screwdriver.
To me, that is the best there is.
Agree - at the point where he said this test was beyond their intended use, I stopped watching that part.As ever, I can't quite understand the value of deliberately breaking tools; you certainly don't learn anything useful. I guess people like carnage.
Have you compared with the Snap-On SSDMR1? That's been my standard for stubbies, but I have to admit that I got the Vessel regular ratcheting screwdriver set and if anything the ratchet feels even better than the SSDMR4. Finer ratchet and less backdrag, although there's a tiny bit of wobble that the Snap-On doesn't have. If I had to choose between the two I think I would have to test them for ultimate ratchet strength before making a decision. Another plus for the Vessel is that IMHO the Phillips (I suspect they are actually JIS) bits are better than even Snap-On for the work that I usually do (most of the time working on old stereo gear which is for the most part made in Japan)
No, not to the SSDMR1. But the standard Snap-On/Williams ratcheting screwdriver is nothing special and I vastly prefer the Vessel to it.
I also sprayed the Vessel ratchet mechanism with Amsoil MP Synthetic spray oil and it made it even smoother. I like the option of the longer shaft length on the Snap-On compared to the vessel, that is about it.
I think I have a single ratcheting screwdriver/bit holder in the house somewhere and it almost never gets used. In my experience, these tools delivery theoretical value and not much actual value.
I have a small Tekton set in a blowmolded case with a not-very-stubby ratching handle that works just fine.
When I need a truly stubby driver, it's very rare and I can handle having it not be ratcheting.
If access is that limited, I'd rather have this:
I can't disagree with that. I didn't mean to suggest that just because my common tasks don't seem to benefit from them that nobody else's would. I'm sure there are kinds of uses for which these could be a real help.I have the Lang version of these (they come in three different formats, flat and two different angles) and they are super handy.
If the other Vessel products I have are any indication, I bet this thing is great though.
However, I have to disagree with your assessment of usefulness. When I need a screwdriver, unless it's for a screw with the head recessed in a "tunnel" or something, I almost always reach for either my Snap-On SSDMR4 or my recently acquired Vessel TD-6816MG. For bits other than the S-O or Vessel, I have a $8 kit from Harbor Freight that does me fine. They can all be used with the aforementioned Lang drivers as well which is super handy. I don't even own a JIS #1 or #2 conventional screwdriver although that is probably something that I should rectify.
Good to know. Yes, I like the overall shape of the SO better, but comparing large to large: Pluses for Vessel: I like the feel of the Vessel better, it comes with 16 bits not 5, the Vessel JIS bits are better for most uses than the S-O ACR bits, and the Vessel kit costs about 1/3 of the Snap-On. Pluses for Snap-On: Overall form factor is the best, and it doesn't have the slight wobble between shaft and handle that my Vessel does.
So, I have both, but had I known about the Vessel before I bought the Snap-On many years ago (if it was even available then) I might have just bought the two Vessel screwdrivers and been done. As it is I may buy the Vessel stubby and put the two Snap-Ons in a safe place... I lent the SSDMR4 to my landlady one day while we were fixing stuff around the house and I realized just how stupid it was to be using a $80 (plus shipping!) screwdriver for around the house stuff. Granted, why have good stuff if you're not going to use it, but at Snap-On prices you start to get real protective of your tools.
Heck, I might get the Vessel just to see what I've been missing. After recently acquiring the Vessel impact drivers in JIS my eyes were opened!
www.cripedistributing.com
Did you try oiling the mechanism ?I bought a heap of Armstrong "gearless" reversible "ratcheting" screwdrivers from Cripe, in both stubby and full-size handles. Intended to give 'em away as presents, keeping a few for myself.
Fabulous idea for a screwdriver handle. Magnet secures the 1/4" hex bits.
Problem is, the "gearless" mechanism slips. Some worse than others. Makes them very aggravating to use.
Someday when I'm more motivated, I should see if a different lube in the mechanism would make them work better. If they were trustworthy, they'd be a go-to.
Armstrong Gearless Ratcheting Screwdriver Handle 2-3/16" Long USA 66-582
Armstrong 66-582 Gearless Ratcheting Screwdriver Handle, 2-3/16" Long 1/4" Female Hex Hole USA Magnetic No neutral gear Gearless (turns smoothly and silently, no teeth to make a clicking sound) Aeronca x 20 55weiser w7b1www.cripedistributing.com
There's a full-size handle version of this, but it's not on their web site now. Sold-out, or just waiting for more interest, I guess.
I would think that would be counterproductive if it's slipping, those gearless things rely on friction to work. But now I wanna try one, I have one gearless ratchet but no bit driver.Did you try oiling the mechanism ?
I used sewing machine oil in a gearless Wiha “ratcheting” screwdriver.I would think that would be counterproductive if it's slipping, those gearless things rely on friction to work. But now I wanna try one, I have one gearless ratchet but no bit driver.
I have a few of these that I use often. I like them. No issues so far. For the price, they are great. So smooth. I plan to get a few more while I can for future use.I bought a heap of Armstrong "gearless" reversible "ratcheting" screwdrivers from Cripe, in both stubby and full-size handles. Intended to give 'em away as presents, keeping a few for myself.
The problem with the vessel is it doesn't fit regular bits very well and has no magnet. I have it and use it pretty often but it has its shortcomings.
The Wera is a nice compact driver but I've always been underwhelmed by their ratcheting mechanism.
The Snap On isn't as stubby as some others but you cannot beat the feel in the hand. It is just a joy to use.
I've been meaning to pickup the PB for comparison. I agree with the above that the PB and Snap On both could use shorter shafts to truly fall into the stubby category.
So the end of the stubby (TD-6700) is not the same as the full size? (TD-6800) that is disappointing as I am growing to like the latter.
And don't forget, a hex to 1/4 adapter,you can put a socket on it,hose clamps is what I use mine for
Are the bits in those good quality? I've seen similar sets under every "brand" known to man.I'm pretty sure this is the same set that's sold at HF for $8-9, I don't expect these to stand up to high torque situations but it comes with the very adapter you mention and also just has a whole mess of useful bits. And if something breaks I stop on the way home from work and get another one.
Astro Pneumatic Professional Screwdriver Bit Set, 100pcs. 9448 | Zoro
Order Astro Pneumatic Professional Screwdriver Bit Set, 100pcs., 9448 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.www.zoro.com
I have Snap-On (flat blade and Phillips) Vessel (JIS) and PB Swiss (Pozidriv) bits for the hard jobs but reach for this kit for pretty much everything else.
I've wondered about these a few times. They accept 1/4" bits but the proprietary bits with half of the handle look really nifty.
