Thoughts on the Proto Box Wrench Set vs. The Offset Box Wrench Set
jgeoffr
Wamsutta
Amarillo, Texas
I don't use a deep offset very often. Like the description says, they're for fasteners down in a recess. Most of the time you can get a fastener that's down in a recess with a socket, UNLESS the area directly above the fastener is blocked; in which case the deep offset wrench is a life saver. And one thing to mention is different brands have different offsets. 45 degree is most common while a 60 degree will get you down deeper. If I was to get a set, I'd get a 60 degree set. The J1100R set would be more handy for everyday use.
malacti
9/16” is for a 3/8” bolt, which industrially is used for almost everything. Lots of times where you need to double wrench it too, thus the two wrench’s being supplied.
J
jgeoffr
Thank you both for the feedback!
AEAdam
SE PA
Don’t buy offsets until you need them. The opposite - 0 offset, is the better choice. Normal combos are usually 10-15 degree offset on the box end.
CHI_Tool&Die
Chicago, IL
I get by at work with the deep offsets in SAE and some DOE wrenches. I find I don’t need to use sockets as much with the deeps being available to me.
