I need to upgrade from my little "stacked hot dog" baby compressor. I run some air tools, an HVLP spray gun, and I have a "barrel blaster" budget bead blaster that the specs call for 12 CFM @80psi.
I loaned away my IR garage mate vertical compressor. It was only good for 5cfm and I had to wait a lot for the air to catch up for the bead blaster. Now I rarely have projects, but when I do, like the pair of tractor rims I need to strip, it'll be a lot faster if I'm not waiting around.
After reading here, I'm very interested the made in the USA Quincy compressors.
In their single stage line- there's a nice 120v horizontal (portable) model that will fit right under my work bench and be out of the way. Rated at 7cfm, so I'll still be waiting, but that's a sizable upgrade over my old 5cfm.
Then there's the beast- the 230v 60 gallon vertical. I do have a 240v plug behind my work bench. The issue is it's going to a very tight squeeze and I'll loose 2 feet of my 8 foot work bench.
I'm worried the 230v will be much louder- it runs at 1250 vs 805rpm for the littler one.
See my photos- I can put the portable right under the bench, or put the 60 gallon against the wall where cords are hanging.
The models I'm looking at are:
Q13160VQ for the portable and the
Q13160VQ for the vertical 60
