Isn't that just the crank case breather?
It looks like your compressor was tipped over at some point and the hydraulic unloader valve was JB welded back together. I am thinking it has gotten into the valve and is preventing the diaphragm and piston from moving which cuts off air to the unloaders once there is oil pressure. You definitely need a new hydraulic unloader valve. I would also ditch the constant run pilot valve hardware if you aren't going to use it. Then you just need one signal line from the tank to the unloader valve, then one from the valve to the unloader tower. The hole should only vent the air once per cycle.
Ok, so the problems continue. I took the hydraulic unloader apart, it's a very simple thing, just a rubber diaphragm, and a brass disc. It seemed loose, so I cleaned it, tightened it up, and I ran a tap through the top fitting threads, because they seemed to be binding up.
So now that it's all back together, the pump runs but only unloaded.
Before, the pump would run, and then start making air shortly after, except it would drain through the unloader, at least until I pinched the line.
I'm at a bit of a loss. How did I suddenly change this thing to only run unloaded....
It's definitely not been dropped. The black goop you see on the fitting to the unloader is RTV. Those threads were messed up a bit, and the pipe thread fitting wouldn't turn in. (This is how i got it) I ran a tap though it and now it's fine. There's no physical damage on this thing, other than the oil filter being beat up a bit.just went through something similar on my quincy. I rebuilt my hyd unloader, after installing it my compressor would only make 30 psi then sit there unloaded. after seeing someone mention it looks dropped, I think you need a new hyd unloader. I thought i got mine rebuilt just fine but i messed up somehting in there.
