I got my Mr. Heater up and running in my 3-car garage, so getting back to looking at shoring up efficiency / air intrusion as best as I can. This house came with Clopay T52S doors which have 1 5/16" polystyrene built into the panels - only an R value of 6.3. Any suggestions on what I could do to help the panels out? Maybe some reflectix / double reflective pieces mounted so there's a 1" air gap from the surface of the panel?
Doors face NE - I notice a hearty N breeze will blow the door in a bit and can see light thru, etc. Attaching a couple pics of the double door at rest and me pushing on it to show the gap at rest. There's a couple adjustment points low on the door, and then nothing until almost the top of the track, and it seems to sit against the outer vinyl weatherstripping ok as is - not sure if it's worth adjusting the doors a bit further out? Maybe brush seal, or putting some foam on the inside of the door trim would help minimize any impact?
Thirdly, the panels have some gaps that draft a bit. They vary in width thru the length of the panels that have them - generally the gap is smaller by the edges of the panels and larger in the middle. What's best to help seal these - some thin foam strips?
Thanks for any help!
