Starrett No. 185 Drill and Wire Gauge
Silverhair
Northern Virginia
To this as a part of a $12 estate sale bundle (also included a Craftsman four-drawer portable too chest) and did my best to clean it up in evaporust. Question is, is there anything else I can do to restore its appearance (to make it more legible)? And, are these things still used? I see Starrett still sells this model though it has been changed a bit in format and such.
I have a few similar, and I think remarking the recesses is going to be the only fix. I can tilt it to make it more legible, but still not very readable
slowtwitch73
Hellgate
I have a number of gauges like those.. pretty antiquated. Lot easier to throw the digi calipers etc on whatever you need to measure.
2oolhound
BC Canada
That's night and day Don. Looks good.
I keep the drill index units mounted by my drill press so it's just a one hand operation and find they work great for putting away drills that have been left out or confirming a size. I tried painting over the numbers with a yellow paint pen and then wiping the surface off after a bit so only the paint in the stamped numbers showed up but it didn't work that well. Maybe I wasn't being careful enough or impatient. As long as the 1/16ths sizes show up it's easy to figure out the 32nds and 64ths in between when you're poking drills in. If I had one for those tap drill sizes I think I'd keep it in my tap drawer. I've bought those 120 drill kits for the numbered/lettered drills and they are all marked for sizes beside the sized slots in the metal cases so no real need there for these cards.
leg17
Kentucky
..... I tried painting over the numbers with a yellow paint pen and then wiping the surface off after a bit so only the paint in the stamped numbers showed up but it didn't work that well......
Use a paint stick. That's what they are made for.
senlow
Wheat Ridge, Colorado
If the surface is not too pitted, I like to do a slow rust blue on the plate and then flat sand the surface. I expect that cold blue would work, but it's not as durable. I have better luck with this method than screwing around with attempting to wipe paint off the surface while allowing it to remain in the engravings. By the time I get the paint off the surface, I typically end up wiping it out of the engravings. Paint sticks work better, but still give me trouble.
