Mike'smeatshop
- Joined
- Apr 1, 2023
- Messages
- 1,273
I am not sure either. But maybe part of the washing machine?I would describe that as a double ended spring loaded socket wrench? It looks like one end has a spring and the other end has a magnet in it? Being 13/16" it makes me think of a spark plug with the magnetic retention or possibly a lug nut wrench with the spring loaded ejection (although 13/16" lug nuts are not very common anymore). If it were to be used like a socket I would expect some sort of holes to be drilled through each end in order to stick something through said holes to give you a handle to turn it with. Not sure how you would get good torque on it as is. Also not sure how it would be used on a washer or dryer.
My thoughts also. May connect a handle to something inside a machine?Some kind of small drive shaft?
Thanks. That just verifies I didn't ask here before. Thought I am loosing it.That could be a removable drive shaft, put the spring loaded end on first, it will snap back to stay in place. Never seen one on a washer or dryer.
I have similar pieces on several pieces of equipment. Not that big tho.
