The inexpensive Harbor Freight tester will give you an analog relative indication; IMHO that is all I expect of a device that sells at that price point.I have the basic HF cheapie pile load tester, that's usually good, but I have a battery or charging issue, where the problem may be borderline.
Looking for an upgrade on a tester, under $100 bucks.
Get an amp clamp
How does amp clamp work?I vote for the amp clamp too, I've been issued with all manner of fancy battery testing technology over the years.
DC Amp clamp and a voltmeter has always been my favourite method for diagnosing borderline batteries.
Is it easier than battery tester device?
What does your $329 code reader do that a $25 OBD2 reader can not do?![]()
ZR15s OBD2 Code Reader with 3.5 In. Display and Active Test/FIXASSIST
Amazing deals on this Zr15S Active Test Obd2 Code Reader at Harbor Freight. Quality tools & low prices.www.harborfreight.com
There is some learning involved and you won't get a traditional pass/fail result. No it won't be easier
Essentially most modern pro battery testers do a few different things to get to a decision. Batteries can fail in numerous ways and the testers are designed to simplify the result (but can be misleading)
1. They perform a conductance/internal resistance test by passing a current through the battery for a few seconds
2. They record Voltage/Current (using a clamp) during a prompted sequence of events carried out by the tech (initial voltage cranking/loads/rpm/drain amps)
3. Temperature compensation
4. Monitoring/comparison of current absorption (over a specified time period usually 5 mins)
5. They then use all this information against the inputted spec/type of battery and an algorithm decides pass/fail
Using a voltmeter/current clamp you can do a very effective version of this type of test by monitoring current absorption over a 5-10 minute period which a lot of cheaper testers without an integral current clamp function will miss, a discharged battery will absorb a high current compared to a failed battery which will refuse to accept much charge, if you add in initial voltage, charging voltage/AC ripple/DC current and an acceptable post test amp drain, you can make a pretty accurate decision with experience.
Bear in mind even the most expensive testers are not 100% accurate, and this type of testing is a more of a quick field test for discharged/defective batteries (where you don't have the luxury of a stable fully charged battery)
For my personal money, I would much rather invest in a good Volt meter (with Min/Max) and a quality amp clamp (and learn a new skill) than spend $500 plus on a pro battery tester every time.
In fact Picoscope software will do almost all of it automatically in a preset test and you can do way more testing with that equipment (a much better investment than a midtronics unit in my opinion).
Even Pico says battery testing is hard. It's certainly more valuable IMO than the midtronics units, I don't trust those for basically anything. 12.5volts, 550cca/600cca - Replace battery? Yet I have a battery it passes, which will not start this Camry? I have yet to see the Pico test lead me astray.
IMO the best option is 2min with the key on, headlights on, see if it starts. If there's any question, the battery will fail. Now with more LED lights, the headlights aren't much of a load. However as newer cars demand more current to be in the ON position, I think it's a wash. I know people dislike that test, as it will kill/fail a mediocre battery. But my preference is to kill the battery in the shop, when the battery's health is already in question, than some cold night in a parking lot at 10pm.
Click the link, and discover.
Maybe you could read the description of the product?What does your $329 code reader do that a $25 OBD2 reader can not do?
IMHO, the best Battery/Alternator/Starter tester was the old Sun VAT-28 or Sun VAT-33.
Great tool, even today. Great nostalgic garage art, especially with its stand !
That doesn’t seem simple at all, versus just testing the battery and charging outputFor a DIYer, the simplest way to test a battery is
Simplest way to check an alternator is check the voltage immediately after starting. Should be between 14.0V and 15.0V. After 5 or 10 minutes it will drop, but not below 13.2V
- Clean the top, especially around the posts ! Make sure the battery terminals are in good condition and tight.
- Charge it overnight
- Remove the charger. Check the voltage. A fully charged battery should be at least 13.2V. If it is less than 13.0V you have a bad charger or a bad battery,
- Turn on the headlights and high beams. Wait about 10 minutes and check the voltage. It should be above 12.0V, your battery is weak. Start shopping.
I got the $25 one. Should be fine for occasional home use.For my personal money, I would much rather invest in a good Volt meter (with Min/Max) and a quality amp clamp (and learn a new skill) than spend $500 plus on a pro battery tester every time.
Okay, the CHEAP DIY method !That doesn’t seem simple at all, versus just testing the battery and charging output
Test a couple known good and known bad batteries before you make that determination.......................I got the $25 one. Should be fine for occasional home use.
There are tons of Youtube videos where people tested it against more costly "pro" chargers.Test a couple known good and known bad batteries before you make that determination.......................
Diagnostic tools are one type of tool that cheap will burn you eventually and you will be chasing your tail. I used a cheaper midtronics tester, still 10 times more then a 25 dollar tester and it worked for the most part. Until I was chasing an intermittent no start. Used tester and it tested good. Moved on and spent a bunch of time chasing other ****. For fun I took battery to napa to have them test it. Bad cell in battery. My tester still tested good. Ordered a new tester from Napa that day and spent a bunch but it's worth it to have a diagnostic tools you can trust. My time is worth more then a cheap tester that may or may not give accurate results.There are tons of Youtube videos where people tested it against more costly "pro" chargers.
Same results. Tested it on a few of my cars and works great
I highly doubt the NAPA tester cost more than $50.Diagnostic tools are one type of tool that cheap will burn you eventually and you will be chasing your tail. I used a cheaper midtronics tester, still 10 times more then a 25 dollar tester and it worked for the most part. Until I was chasing an intermittent no start. Used tester and it tested good. Moved on and spent a bunch of time chasing other ****. For fun I took battery to napa to have them test it. Bad cell in battery. My tester still tested good. Ordered a new tester from Napa that day and spent a bunch but it's worth it to have a diagnostic tools you can trust. My time is worth more then a cheap tester that may or may not give accurate results.
You highly doubt? How does some random guy on the internet doubt how much I paid even though I specifically said it was way more expensive then your 25 dollar tester. My low end midtronics was 250. My new one was 3 times that. No clue if a cheap 25 dollar tester would have been more accurate then my 250 dollar midtronics or not. But I wanted a tester I could trust so spent 800 on a new tester. It's a tool that I don't use but a few times a year but at least I know when I use it that I can trust it.I highly doubt the NAPA tester cost more than $50.
The question is would the $25 tester have told you to replace the battery?
For a no start, after full charging overnight, first thing I'd do is replace the battery if its over 3 years old.
Lowest hanging fruit
On the other hand batteries aren't a terribly complex device to diagnose.
I'm sure your 25 dollar tester will work most of the time and be a good quick check. But it's now where near what a pro level tool is.
An absolute must have.If you know how capacitance testers work you will know they won't find every bad battery, just how their technology is. Even the most expensive ones. Still need a toaster tester that can do half the cca amps to test another way. I have a 500 amp toaster tester to use a long with my capacitance tester.
Given the analog design, like a needle volt meter etc, you simply tweak the screw below the display to 'zero' the deflection. I used my Fluke meter to benchmark the voltage and adjusted the HF load tester accordingly. Takes secondsI have the cheapie HF 100amp carbon battery tester also. Funny thing, I once compared it against multiple multimeters and a Clore battery tester (the one buckaroo just linked), and the voltage reading of the HF one was way off from the others, by about 0.7 volts-ish. don’t know why, maybe the sticker was placed off, maybe it has degraded over time, or perhaps it is just a pos.
