Inline 240v outlets 6-50r and 14r
Xkylescorex
So I have my welder on a dedicated circuit using 10/2 wire. So two hots and a ground. Of course my powdercoat oven has a nema 4 prong connection. I was thinking since the plug is near the panel I could just jump off my welder outlet and then run a dedicated nuetral over to the box . Mainly because I have 10/2 and dont want to go buy a new length of 10/3. I see there are adapters on amazon to go from 3 to 4 prong but that wouldnt solve the problem of not have a nuetral on the oven plug and from what Ive read is dangerous. Also dont want to shell out for another $40 breaker since I will never use the two plugs at the same time and will probably use the oven twice a year
mike93lx
Richmond, VA
If the oven is higher than 5750 watts, #10 isn't big enough anyway.
I bet you need to run a new wire, probably 8/3, which would also mean a 40a breaker as you can no longer have it be welder only. Keeping a 50a breaker will require 6/3, afaik
mm08822
That's where I was heading. Once the stove is on the welder circuit, the welder exceptions go away.
dave*99
Coastal NJ
I agree..... But I didn't see the OP mention having a 50A breaker on the existing welder circuit.
mm08822
That's the problem with many threads. There isn't sufficient information given so all one can do is ask q's, guess or assume.
The replies cover the spectrum of "what ifs" and the thread takes a right turn quickly.
mike93lx
Richmond, VA
This is the internet, not paid-for professional advice. It is how it goes and how it always will
X
Xkylescorex
I have welder on a 50 amp. After lots of research Im just gonna pony up and do it correctly. Run a direct circuit. Got the oven free off next door so a $40 breaker and $30 for a few feet of 8/3 guess I gotta pay to play
