The best tool to split plastic barrels
TxMN
North Central TEXAS
Needing to split a few 55 gal plastic barrels to use as worm beds. Tried once to cut top out of one with reciprocating saw and it did not work very well. Ant tips or suggestions to tools/ blade choices/ or methods appreciated.
The plastic vibrates too much with the recip action, even when held tight against the shoe. DAMHIKT. Maybe with a super fine blade (jigsaw) it might work. The plastic on many is so thin, it just rides the teeth.
I did mine before I had my OMT, but seems like cutting along the flat, instead of down the edge might work.
Buddy tried a circ saw, threw pieces of plastic everywhere. Hell of a cleanup job.
Cut off wheel might melt the plastic, don’t know. Seems you’d have to move fast.
GirlnAgarage
Texas
Use a oscillating tool w a bimetal blade. Same idea as recip except more refined cutting with less violence.
I used an oscillating tool to cut away plastic pots after tree roots had grown through them and I had to do surgery to remove the pot to plant the tree. It worked well.
flyingblind
Washington
I had to chop up a few (50 Poly LC HF) for disposal and just a circular saw worked best. No backward blade just go. I had to cut them in quarters to fit in the dumpster.
sea2summit
Angle grinder.
But I use a reciprocating saw most of the time, just **** the stop against the barrel and keep pressure on it and aggressive teeth work best for me.
PCustoms
VT
Been a few years, but I always used either a recip or a jigsaw.
Don't go too aggressive on the blade.
Dig Doug
Tip the barrel on it side and mark your cut lines all the way around
cut With a fine tooth / like with a 40, 50, 60 tooth skill saw blade - it will cut like butter !! We used to do it all the time and make job site trash cans…
ChevyEFI
Phoenix, AZ
They may be too thick for this to be ideal but a blade that cuts deeper each pass (similar to a tubing cutter function) could be labor intensive but give clean cuts. Getting the line straight could be the hard part.
Pexto
I cut the tops out of a couple of 55-gallon HDPE barrels last year; we use them to collect rainwater off the roof. I just used a standard wood blade in a jigsaw. Fast cutting and easily controllable - really no big deal.
dogdog
higher tooth count circular saw blade as mention on post #2... I used 90 or more count blades for those clear plastics plexiglass
something like these . Maybe a 60th would work also but might chip.
mike93lx
Richmond, VA
Plastic barrels aren't really brittle, they're hdpe. I would bet whatever blade is currently on the saw will do fine.
dogdog
they are thinner, and will tear out with a lesser tooth blade like the normal 24T ones.... I have cut my garbage cans up before for recycle but that is because I don't care about the tear .... this is because it is more flexible
also set our blade depth as shallow as possible not the full plunge... I just set 1/4 or 1/2 maybe less
BombShelter
State of Hockey
There are CS blades for plastic, the issue is with no support it's hard not to get the plastic rattling. Maybe build a 2 x 4 frame and stick it inside to support the plastic.
MoonRise
Phased plasma rifle in the 40 watt range. :lol:
Fine tooth (high tooth count per inch) blade in a jig saw, or recip saw, or a circular saw. With a circular saw, one trick (as mentioned) is to install the blade BACKWARDS so that the cut is waaaay less aggressive (trick works well on vinyl siding).
If the recip saw attempt didn't work out well for you, tell us WHY. If it was because the saw or the plastic bounced or vibrated too much, then a variable speed jig saw with a fine tooth blade should be more controllable. The usual trade off of coarse tooth = fast but rougher cut versus fine tooth = slower but smoother cut applies here as always.
OMT will do it, just a little slower.
Cut off disk in an angle grinder will do it, might be more like melting through the plastic though. Not that there's anything wrong with that. 😁
Katana. Maybe a magurokiri :lol: Semi-seriously, a decent sharp knife should be able to cut through a plastic barrel.
Water jet cutter.
Laser cutter.
Hot knife cutter.
Hot wire plastic cutter, although I don't know if that will be able to get through the plastic barrel as you haven't given us any idea of how thick the plastic that you are dealing with is.
mike93lx
Richmond, VA
Water jet cutter.
Laser cutter.
Hot knife cutter.
Water jet is the best suggestion so far.
no704
4 1/4 angle grinder with a chainsaw disk. I think this is the first reasonable use for one.
