TxMN
Needing to split a few 55 gal plastic barrels to use as worm beds. Tried once to cut top out of one with reciprocating saw and it did not work very well. Ant tips or suggestions to tools/ blade choices/ or methods appreciated.
Or a laser tuned up by Binford.Can’t believe I’m going to be the first to suggest an O/A torch.
I can.Can’t believe I’m going to be the first to suggest an O/A torch.
Chain.chain saw & sharp blade
I can’t believe you took the bait.I can.
Sounds like a stupid idea to cut plastic.
Plastic barrels aren't really brittle, they're hdpe. I would bet whatever blade is currently on the saw will do fine.higher tooth count circular saw blade as mention on post #2... I used 90 or more count blades for those clear plastics plexiglass
something like these . Maybe a 60th would work also but might chip.
Avanti 7-1/4 in. x 140-Tooth OSB/Plywood Circular Saw Blade A07140A - The Home Depot
The Avanti 7-1/4 in. x 140 Tooth OSB/Plywood Circular Saw Blade is an economical, high performance replacement blade. It is recommended for hardwood, plywood and oriented-strand board. This is made ofwww.homedepot.com
they are thinner, and will tear out with a lesser tooth blade like the normal 24T ones.... I have cut my garbage cans up before for recycle but that is because I don't care about the tear .... this is because it is more flexiblePlastic barrels aren't really brittle, they're hdpe. I would bet whatever blade is currently on the saw will do fine.
exactly! drill a hole, insert blade and start cutting. never had a problem doing it this wayjigsaw is what i use
But jigsaws are ewaste.exactly! drill a hole, insert blade and start cutting. never had a problem doing it this way
what about drills? just use a hammer and punch insteadBut jigsaw are ewaste.
THIS^Circ saw with blade backwards.
Semi-seriously, a decent sharp knife should be able to cut through a plastic barrel.Water jet is the best suggestion so far.Phased plasma rifle in the 40 watt range.
Fine tooth (high tooth count per inch) blade in a jig saw, or recip saw, or a circular saw. With a circular saw, one trick (as mentioned) is to install the blade BACKWARDS so that the cut is waaaay less aggressive (trick works well on vinyl siding).
If the recip saw attempt didn't work out well for you, tell us WHY. If it was because the saw or the plastic bounced or vibrated too much, then a variable speed jig saw with a fine tooth blade should be more controllable. The usual trade off of coarse tooth = fast but rougher cut versus fine tooth = slower but smoother cut applies here as always.
OMT will do it, just a little slower.
Cut off disk in an angle grinder will do it, might be more like melting through the plastic though. Not that there's anything wrong with that.
Katana. Maybe a magurokiriSemi-seriously, a decent sharp knife should be able to cut through a plastic barrel.
Water jet cutter.
Laser cutter.
Hot knife cutter.
Hot wire plastic cutter, although I don't know if that will be able to get through the plastic barrel as you haven't given us any idea of how thick the plastic that you are dealing with is.
