Greetings, I find myself in an unknown area. I have a generator I want to add a remote shutdown and over temperature switch to protect the generator. The remote switch seems simple enough but I cannot grasp what to use for the temperature switch. The highest temp I have seem in the generator area is 104 F so thinking 110 degrees F would be sufficient. What would be the easiest, cheapest type of heat sensor to accomplish this? Looks like it needs to be normally open and close at 110 F. I have no idea what the voltage or amps are in the generator? Honda EU2200i, yes has blue tooth to shut down but in a faraday cage and I see no way to add a external blue tooth antenna.
