Dakotadadv8
- Joined
- May 30, 2021
- Messages
- 1,513
Old thread. Also have CM 12 point set 1/2 drive 10 to 21 from Lowes, only skip 20mm, under $50. No big deal can't remember ever using 20mm as DIYer over the last 25 years.
Almost 50 years of shade tree wrenching. NEVER needed a 12 point socket ! When I ran into a 12 point fastener, I used a combination wrench.... can't remember ever using 20mm as DIYer over the last 25 years.
I had to take out this bolt in my Audi, got a 19mm single socket, about 7eur, done. Will probably never use it again.I know this is an old thread, but if anyone googles this and this thread comes up I want to add one I just came across that isn't mentions.
VW 2.0 SOHC (and possibly others) harmonic balancer bolt is a 19mm 12pt (some of them can also take a triple square, but I trust a 12pt impact socket on a high torque 1/2 impact wrench over a triple square).
It was with shear dumb luck that my 1/2" drive 19mm shallow impact socket just happened to be one of the very few 12 point sockets in my impact socket drawer.
I giggle when I can remove something that isn't rusty. It's like you're not even doing anything.It's basically not even "working" on cars without rust and rot. You're just removing stuff. LOL
See, all those years of being a male ****** do pay off.Like, why did I buy tools for this. I could have removed it with my tongue.
Exactly.See, all those years of being a male ****** do pay off.
What tool is that you got holding that still?? I could have used that tool when I was working on the VW!
Great job on the sprocket holder! I used to build and repair industrial gearboxes (speed reducers). My boss always claimed that "special factory tools" were for people who lacked imagination. We always made our own. Those aren't old bed frames are they? GJ bonus points if they are, lol!
Your boss would have a very, very rough time on modern automotive engines.
Yes, the replacement bolt ("always replace") also had a triple square in the center. The one in the car was 20+years old and managed to remove it with a 2.5meter 2" galvanized pipe on a 1/2" Hazet extendable ratchet (pic). Surprised the 19mm socket held and didn't break, moreso for the ratchet. Had to remove it to replace the front main seal behind it.What tool is that you got holding that still?? I could have used that tool when I was working on the VW!
And that's the same bolt I was talking about on the same timing belt gear. Only difference is the one I was working on could also have a triple square in the center, but I trusted the 12pt more (on a high torque impact at least)
The "special tool" I made from new 4mm thick L steel stock. Used some washers on one side to compensate. Held very well against the concrete floor, was also used on the opposite side to tighten the replacement bolt.Great job on the sprocket holder! I used to build and repair industrial gearboxes (speed reducers). My boss always claimed that "special factory tools" were for people who lacked imagination. We always made our own. Those aren't old bed frames are they? GJ bonus points if they are, lol!
dTHAT is one nice looking ratchet!Yes, the replacement bolt ("always replace") also had a triple square in the center. The one in the car was 20+years old and managed to remove it with a 2.5meter 2" galvanized pipe on a 1/2" Hazet extendable ratchet (pic). Surprised the 19mm socket held and didn't break, moreso for the ratchet. Had to remove it to replace the front main seal behind it.
The "special tool" I made from new 4mm thick L steel stock. Used some washers on one side to compensate. Held very well against the concrete floor, was also used on the opposite side to tighten the replacement bolt.d
