YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 501
I know that impact sockets, the walls are much thicker, and the overall height of an impact socket, is much greater than chrome sockets. Even for thin walled impact sockets or shallow impact sockets, chrome is much thinner and shallower. I can see situations in which you would need a chrome socket over an impact socket, such as oil pan fasteners with a lip on the oil pan, or tight clearance areas like on a timing chain cover, or under the dash work. However these fasteners seem to be mostly 14 mm or smaller, and a 1/4" drive socket will work. Because clearance is of concern often in these situations, using the smallest drive size would make sense, 1/4", as braker bars, ratchets etc. are often the lowest profile.
However for 3/8" and 1/2" drive, I don't see nuts or bolts in supper tight clearance areas whose sizes are greater than 14 mm. It seems like I might be able to get away with impact sockets only for 3/8" and 1/2" drive for automotive work?
If anybody has ran into the situation in which a fastener had to be removed whose size across the flats was greater than 14 mm, and an impact socket would not work due due wall thickness or overall height of the socket, and HAD TO use a chrome socket as a result, please let me what this situation was.
Thanks.
Thanks.
