In theme with my shop name I wanted a double bass drum pedal setup to further disturb the peace. Most everything on the market is backwards and the right setup is 2-3x the cost. Nothing used available. I bought a cheap ($80) pedal kit to reconfigure properly.
The 2nd pedal was easy enough, swap direction of axle, just needed a tension screw mount on other side. Tap one hole, attach bracket. Now driveshaft exits left for right foot use.
The main pedal assembly is more complicated with split axle for each whacker. The center bearing support was fastened with screws, so easy to move to other side with just a few holes drilled.
Swapped axles and HW side to side. Index everything correctly.
Assembly back together and ready to go. Double pedal functionality aside the new pedal is better and way easier to play than the old, even though it is the cheapest turd on amazon. The brutality of the double bass is fun.
