KSV
To Chevota Guy, just joined Garage Journal, and I received a notice that I can’t PM you until I rack up 10 posts first. So.... this is post 1.
Send me an email and I'll reply with the PDF docs of the tables. They aren't drawings or plans but I photographed the build and annotated dimensions that should be easy to replicate.I am thinking about buying a Dewalt 7491rs to replace my Delta contractors saw due to space. These infeed and outfeed tables look like the ticket.
I just picked up the 7491RS a few months ago...was able to build an outfeed table using plans that looked similar to Chevota's.Send me an email and I'll reply with the PDF docs of the tables. They aren't drawings or plans but I photographed the build and annotated dimensions that should be easy to replicate.
**** Mahany
Nice work!!If it is the 7491 RS, it is one great saw. I downsized from a 3HP Unisaw and went with out a table saw for a couple of years using only a track saw. I wanted to rip narrow pieces for face frame and door frames and got the 7491. It has really surprised me about how capable it is.
I run full kerf Forrest WW II blades with out problems and it spins a full sized 8" dado just fine. Of course the feed rate is slower than my old cabinet saw, but it is a well built tool for the compromises that have to be made with lightweight portable jobsite saws.
I took the time with a dial indicator to make sure that the miter slots are parallel to the blade and likewise for the rip fence. Very little tuning was needed, but the adjustments are designed into this saw if needed. The fence is a strong point on this saw, however the included miter gauge is worthless. I replaced mine with an Incra model that is excellent and added LeeCraft zero clearance inserts for tear out free work.
I built an outfeed table and an infeed table which have greatly enhanced the performance and versatility of this saw. You'll be happy with the 7491RS for sure.
View media item 98481
The outfeed and infeed tables attach to the saw without tools. The infeed table allows the crosscut sled to be fully retracted in font of the blade without tipping.
View media item 98494
View media item 98482
For those who find the fence not sufficient, a reversibile aux tall and long fence may be helpful. I like feather boards and this fence has been very handy at times.
View media item 98483
View media item 98484
If any of these mods might interest you, PM me as I have documented the building processes in PDFs. Although not "plans" per se, will share freely.
For those who disdain lowly "jobsite saws"................ Maybe think again
UPDATE 11-17-2020: I learned that DeWalt changed the upper rear cross member from tubular to a flat C-channel sometime after my saw was built (Type 2 manufactured 2017). Fortunately the overall outfeed table concept is still valid but the "hook" feature of the support wing will need to be adapted accordingly.
I use the stock riving knife on my 7491RS with several different full kerf Forrest Wood Worker II blades and haven't had problems. (I have never used the stock blade). If I ever think the riving knife needs to be thickened up, I'll just add a layer or two of aluminum duct sealing tape, but for now I don't see the need.I just bought this table saw and I am looking at blades. Would love to put a full kerf WW II on there with the stock riving knife. Chevota Guy says this works...with the riving knife? Looks like it is on in one of the photos, but the blade is not shown. Anybody else have comment on that?
You're my kinda guy. I love that duct sealing tape and use it for everything (so does my 9 year old). Thanks!I use the stock riving knife on my 7491RS with several different full kerf Forrest Wood Worker II blades and haven't had problems. (I have never used the stock blade). If I ever think the riving knife needs to be thickened up, I'll just add a layer or two of aluminum duct sealing tape, but for now I don't see the need.
Check out you tube for “How I Do Things DIY”. This guy made a folding outfeed table for his Dewalt 7491 RS. So it goes with you and the saw when in the down position. I made one for my new Dewalt 7491 RS. It’s great!I am thinking about buying a Dewalt 7491rs to replace my Delta contractors saw due to space. These infeed and outfeed tables look like the ticket.
I would love to get the PDFs of the 7491 indeed and out feed tables you made, if possible. My email is slandau2002 @ yahoo Thank You!Send me an email and I'll reply with the PDF docs of the tables. They aren't drawings or plans but I photographed the build and annotated dimensions that should be easy to replicate.
**** Mahany
Not yet.Have you used the "the PowerTec crosscut sled and miter gauge" yet?
I would like to have one of those things
Looking into them now!
I used them!Have you used the "the PowerTec crosscut sled and miter gauge" yet?
I really, really wanted to love the PowerTec Miter Gauge.
It's a little finicky to setup with the tiny socket-head screws. But manageable, if you have a good square.
It really tough to get the knurled nuts tight enough to keep the fence in place. I have a lot of finger strength, but there isn't adequate clearance to really grab 'em. Using pliers deforms the plastic knurling.
I like the idea of the compressible rings for tension. Implementation is somewhat lacking. If the fence isn't perfectly centered, left to right, you'll still get some lean and wobble even if it's too tight to push smoothly. Fence overall seems too heavy for the gauge. When set up properly, it is WORLDS better than the stock one that came with the saw, but I still felt it had shortcomings when dialed in to my best ability. Then, after perhaps six passes, the screw securing the leading aluminum ring fell out. I have the ring, but lost the screw. In that condition, it's no better than the stock one. (I'll be buying a new screw, and using Loc-Tite.)
All in all, I like this one and will continue to use it, but can't help wish Santa brought me the Incra instead.
Sorry it didn't work out
Completed side-table build, and routed it out to accomodate the saw stand as a left support table for long items; can be (and was) readily utilized as an infeed table; did pretty good for outfeed, but occasionally the workpiece would catch, or the table would move. Haven't tried it on the right yet. Should be fine, but better on the left. Needs four larger, locking, heavy-duty casters, and a couple more leg supports. But works well once in place. Doesn't fit in the shed/woodshop quite as well as I had hoped.
You can make your 1/4 -20 nuts from Uni Strut Tension Nuts.As it turns out, PowerTec sells the Plate and Screw for like $2.50, or I can try to source a replacement screw elsewhere. M5-.08 flat-head with 3mm socket drive. .309" length might be harder to find.
Looks like their T-Bolts are 1/4-20. So getting some nice, tough metal knurled nuts shouldn't prove excessively difficult.
Maybe I'll learn to love it after all.
Thanks!You can make your 1/4 -20 nuts from Uni Strut Tension Nuts.
Update on the PowerTec Mitre Gauge:As it turns out, PowerTec sells the Plate and Screw for like $2.50, or I can try to source a replacement screw elsewhere. M5-.08 flat-head with 3mm socket drive. .309" length might be harder to find.
Hello, can you please send me the drawings and dimensions for this awesome outfeed and infeed table for my new dewalt 7491RS?Send me an email and I'll reply with the PDF docs of the tables. They aren't drawings or plans but I photographed the build and annotated dimensions that should be easy to replicate.
**** Mahany
May I also the photos and dimensions to this awesome outfeed and infeed table?Send me an email and I'll reply with the PDF docs of the tables. They aren't drawings or plans but I photographed the build and annotated dimensions that should be easy to replicate.
**** Mahany
I am definitely interested in your infeed table pdf doc...as I can't figure out how to build one that requires modification (holes) to mount it (and I'd prefer not to drill holes in
Hello, did you get th PDF's of this extension table?I just picked up the 7491RS a few months ago...was able to build an outfeed table using plans that looked similar to Chevota's.
I am definitely interested in your infeed table pdf doc...as I can't figure out how to build one that requires modification (holes) to mount it (and I'd prefer not to drill holes in my saw).
