Source for odd size steel tube
mrpizza
IL
I need two- 2 foot pieces (18" would work too) of rectangle steel tubing that are 1 3/4" x 2 3/4" to fit inside some 2x3 rectangle tube. Striking out online! It can be 1/8 wall, 3/16, or 1/4 not critical at all.
Is this even a thing, or will I need to cut and weld some tubing down?
mike93lx
Richmond, VA
This place does telescoping tubing, but steel is only square. Their rectangular is AL
mrpizza
IL
Ill just do the shims welded on. This is to make a couple receivers to hold a vice, etc under my bench using some materials I already have.
Spareparts
Lansing Ks.
When I did mine I used 3" X 3" 3/16" wall sq tube and the insert was 2 1/2" square. what ever thickness you want, I also drilled a 1/2"
hole in the side of the 3" tube, and welded a 1/2-13 nut on the outside of the tube, this was for a bolt to secure the inner tube to
keep any movement from the vice. I have done this in several places, 2 on the work bench and even on my service truck for several
years and never had a problem.
Monza Harry
Windsor ON
You could remove the "flash" [raised weld seam"] from inside your outer tube. There was a link here on GJ to a U-tube video of a "DIY" tooling looks pretty easy depending on your length of tube. I keep that plan in mind for future builds that require tubing not available in "flash removed". Harry
VR6ix
Onterrible, Canuckistan
No way that's a common size of HSS tube, adding shims to smaller material sounds like the best solution for what you're doing, or cut-and-form a C- shape 1 3/4 x 2 3/4 x 1 3/4 and weld a 2 3/4 cap on it.
Bigblue&Goldie
For your application I'd go buy some receiver tubing for best fit, but even then it will be a little loose. I think my local supplier sells it for like $40 each. I'd then drill a hole on one of the sides and weld nut over it to be able to run a bolt for tension.
Standard tubing (even DOM and 4130 with better dimensional specs) isn't made to tolarances that reliably allow for telescoping. Sometimes they work together, sometimes they don't. The other issue is tubing is never straight, so the longer the slip fit interface, the more likely they are to bind. Add a seam into the mix and it's a real pain in the ***.
These are some clamp on brackets I made to hold a bike rack to a trailer bumper. Same cocnept as I described above. The pieces can be had for under $20 on Amazon.
i4ni
Ordered a new Hitch and reciever for my wifes Forrester and there was enough slack that it was driving me crazy with the constant slapping up and down so I drilled a hole and welded a nut on like above. Having the ability to tighten down the bolt saved what little sanity I have left lol. I just keep a wrench in with the receiver, a bit of a hassle but worth it. I staked the first few threads on the bolt to keep it from falling out.
danielbuck
for the receiver tube on my vise table, I drilled a hole on the bottom and a hole on the side, welded in some thick 1/2" nuts, and use bolts in them like set screws. works really well. Just one might do, but I did both. Also welded on a "T" handle to the bolts, so that I don't need a wrench to tighten them, can do it by hand.
mike93lx
Richmond, VA
I use one of these to tighten up the ball mount. Works awesome1000003477.jpg
i4ni
Thought about one of those but I went with the nut and bolt. It wasn't bad, took mabe an hour. I will say in the future I'll do the mod on any new hitch I get before installing just because.
LopezBart
Lopez Island, WA
Our old Yakima bike rack has a threaded rod that runs up the center of the part (stinger) that fits in the receiver. The end of the stinger is cut off at a skew angle, and the threaded rod threads into the cut-off piece. When the rod is tightened via a crank, the end of the stinger moves and binds in the receiver, and this eliminates any slop and the resulting noise. This rack hinges down holds up to four bikes. The angle is steep enough that it's completely self-releasing, but still binds effectively.
i4ni
I seen something similar. It works well
Monza Harry
Windsor ON
For my Never, Never welding table [seems it will never, ever be together], I notched and then welded [3rd pic if you look close shows the muriatic acid line on the coating] on some coupling nuts to the receivers for said welding table. However I placed them at 45° to tighten both in x (or y) and z. Here is a few pics:
Harry I don't seem to have a welded pic Sorry [your eyes will thank you (or me?)]
