Ok so in my shop I have 4ft. 6 bulb T5 fixtures. 8 of the 12 fixtures have ballast out so I either have only two or four of the six bulbs working in those fixtures. Been thinking of just converting them all to direct wire LED bulbs. Here is my problem....I popped a bulb out and when I look up the specs on the manufactures website (Halco F54T5/865/HO/ECO/IO) it tells me they are a 54w, 6500k color temp and 4650 lumen. I have yet to find a T5 LED replacement that is more than 3500-3600 lumens, and most are about 5000k color temp at most.
Does this mean I am actually going to loose about 1000 lumens per light bulb or is there some kind of fluorescent to LED wizardry that I am missing here???? I keep seeing these 3500 lumen LEDs referred to as a '54 watt fluorescent equivalent' but I'm not buying it considering the lumen difference....but I don't know much about this stuff. There is no way I'm going to go backwards as far as light output if that is going to be the case. If anything I wouldn't mind more light than I already have (currently have 12 fixtures total in a 40x72 shop with 13.5 tall ceilings)
Do the LED bulbs put out light a full 360* around the body of the light like the fluorescents or do they need to be installed a certain direction-such as they have a string of lights in the tube that only shines one direction? A top and bottom so to say? Mostly wondering if the reflect off the top of the light fixture like the fluorescents do or not?
My other thought was replacing all my current fixtures with LED UFO lights. My electrician cousin has mentioned that to me a few times. I though they were more for high bays though, and at 13.5ft to my ceiling I wouldn't necessarily call mine high bay. Maybe that is still tall enough for the UFOs???
Last idea is just to replace the ballast and keep running the T5 fluorescents. Replace ballast as needed in the future then.
Im not really worried about comparing prices but for shlits and giggles it looks like its about 60 bucks each for a replacement ballast ($480 right now to get me fully functioning again). To go all T5 LED conversion Im going to be around 800 dollars for bulbs or for UFOs it looks like they average around $100 each for a 30,000 lumen one-I assume I would need at least 12 of those also to match my current lighting?
Any thoughts?
Any thoughts?
