Should I upgrade my wire stripper tool ?
Ohmthis
Outside of Louisville KY
I'm pretty sure you do, however for a general purpose wire stripper these are the absolute bomb/and almost disposable cheap. But please watch the video.
They perform better than both the expensive Knipex versions (and all the rebrands) and are made in a first world economy, which will tick a lot of boxes for GJ guys
I would never recommend junk to my fellow tool enthusiasts, I've been in the game myself for nearly 40 years 👍
Thanks for posting this. I’m an industrial electrician and have dozens of pairs of strippers. I’ve been looking for a set of auto strippers that feeds the wire in the front, not the side. I’m going to check these out.
richfinn
Leeds, Yorkshire, England
Do you have a link for the ones you have and like? I'll have to order some
Obviously try your local eBay/Amazon for best pricing 💰
If I'm splicing or terminating anything below 22 gauge (0.5mm) Typically I would use open barrel crimpers and adhesive lined heat shrink tube or the appropriate sealed plug terminals.
BrandonV
Arizona
richfinn
bcradio
New Mexico
Thank you good sir! 😃
Ordered some
bronuc
For the heat shrink connectors crimp tool, I believe this is the one highly recommended by the marine electrical how-to website whose name I can't remember. NSPA is also the manufacturer of a line of heat shrink connectors.
I ended up buying the crimp nests from Pressmaster as I already had the crimper body.
BrandonV
Arizona
I know which article you're referring to. It's one of my favorites.
Glemon
NE
After going through half my adult life 20 years) stripping wire with a utility knife (you do get a feel for it) I got a tool like the OP has used all his life. I completed many projects with it and thought I was living the dream, until I came here and read this thread...
BrandonV
Arizona
So while I'm not a fan of that style partially for anything involving crimping... a good quality version of that tool will be fine.
I have one of those which is a Klein made in the USA. It works great. I think more often that not that style has been copied so many times its associated with being a POS.
Lorydr
Piqua, oHIo
Best strippers both in speed, consistency, and not leaving knicks on the wire.
Works on everything from 10 gauge if you squeeze the handle partially and then rotate 90 degrees down to super fine 30 gauge on tiny encoder leads.
My work has that weidmuller version. Looks the same. It had been gathering dust for more than a decade. I decided to give it a try about 6 months ago, and now it's my go-to for terminals and ferrules. (panel building).
The set I've used for a few decades is similar to the small yellow handled Klein. I use them almost as much still. Small, lightweight, tiny gauge up to 14 awg. (great for light duty household actions). Although I have a similar set for at home. Doesn't matter left or right handed. Made by Ideal. The strippers have remained sharp and reliable...and cheap!
I have other larger strippers that I use for small insulated crimps and small screw trimming. They **** at stripping. I don't have to use them much.
Edit...i meant to write weidmuller instead of panduit
bwringer
Indianapolis
@BrandonV In our business we have 20 full time technicians building electrcial control panels all day long. All they do is route wires, label them, strip them and terminate them. Thousands of connections a day across those folks. None of them have ever used v notch strippers nor would they recommend them to anyone. No one who strips a lot of wire likes them.
OK, so what do those techs use?
I am burning with curiosity.
RyanE
Golden, BC
Ordered some
Same here, before the rest of you do and the price is automagically adjusted (skyrockets) on that jungle site. The current price in CAD is $36, similar to a decent pair of conventional Klein or Channellocks, of which I already have.
These will be my first pair of auto strippers.
Cheers!
Wiz02
Southeastern PA
If you aren't a pro as professional electricians probably scoff at these strippers, but they strip the sheathing from NM cables neatly, cleanly and quickly. So much better than using a knife for me.
isb cornbinder
I just found a picture of two of my favorite ratcheting crimpers. They are identical and different brand names. I was able to buy exchangeable crimp jaws at MOPAC, Langley, BC.
I have three different crimp options, now. The one crimp is for cutting the insulation on spark wire and making the crimps. The spark wire crimper does a perfect job, every time.
In answer to the OP question, "Should I upgrade? Very definitely yes. I have had lots of experience and can say with confidence, "Good tools make the job easier and better." If a person is not doing this for a living, a good tool is a must-have.
richfinn
Knipex make at least three or four versions of those type of strippers and they are really decent quality, the problem I always find is there is never enough room to use them easily and for USA based users they are all metric (at least the stripping function).
Weicon automatics don't care, insert wire up to the adjustable stop to get the correct length and pull the trigger, job done.
If your doing multiple wires it can be a big time saver not having to eyeball the strip length and pick the correct gauge and way less fatigue on your hands as they are super lightweight (new users might feel like they are a bit of a "toy" at first, but you soon get over the fact that they are 95% plastic when you realise consistent performance is what really matters in any such tool).
Steve_P
I don't need another wire stripper as a have a full set of the Kleins, including the Romex ones, but for $25 for the Weicon, I'm in on my next Amazon order :LOL: .
thool
Rochester, NY
The Klein Katapult has the same issue with NM conductors but it doesn't seem to be as bad. When looking at the two, it looks like the teeth on the Klein are more aggressive so they'll get a better bite.
I have the Klein Katapult and it was indispensable when I replaced all my electrical switches and outlets to the "decora" style. It gets a good bite, and I found a brisk squeeze works better than a slow squeeze.
Pinemarten
Washington
I prefer this style.......
There are many brands out there. The Capri model is typical of the type (and the first one I found online)
sparky 1971
Central Iowa
I have a set of these from when I started a long time ago. I don't care for the stripper and cutter, but I do keep them around and use them for cutting screws that aren't 6/32 or 8/32. They do work much, much better than the joke in post #1.
I use these for strippers. I get about a year out of them using them daily before the cutter gets too dull to go cleanly through stranded wire. With occasional use, they would probably last a lifetime.
