5" random orbital corded sander... mostly for metal finishing
VR6ix
Onterrible, Canuckistan
I searched around and didn't find any tasty nuggets so feel free to help :beer:
Looking to add a corded Ø5" random orbital sander to my fleet and it's mostly going to be used for metal finishing instead of woodworking. So the vacuum and bag system really isn't a priority, but, it will get used on any odd job that comes up. The abrasive media will primarily be 3M Stikit PSA discs which do not have the dust collection holes. I have a plan to adapt the Velcro sander base plate so I can use the stick-on sanding discs, so that's not an issue. I don't have the CFM to run air tools.
My initial front-runner was the Metabo/Hitachi HPT SV13YST. $82 Canuckistanian Copeks on the ol' ScAmazon right now.
What other options should I be looking at? Must be corded, must be Ø5" - buy once, cry once, I'd like a tool that is comfortable to use that I will keep around for a long time that doesn't cost more than a couple cases of beer.
Steve_P
Have you looked into burnishing tools. I use mine all the time for finishing and sanding metals.
Not sure how many high-quality power tools ever cost only two cases of beer, but...
I mean, do you cry over the cost after you drank two cases of beer?
I have a Makita i'm fond of, but it uses Velcro, suspect they make a PSA version.
neophyte
Pennsylvannia
Older “Professional” US made power tools used to routinely cost less than $200, with many at $150.
That might have been more than the cost of two cases of “standard beer”, but it was still somewhat affordable.
I think my USA made Dewalt random orbit sander was $90, snd I still have it and use it.
NORTON'S SHOP
Upper Midwest
Pick one. Good luck finding both.
cnc-me
MI
Porter-Cable 330 if you can find one.
For hobby use you will never wear one out. They are built like tanks. I think we had 6-7 in use full time, and I think they would go
3 years or so before they started needing parts and service. Mostly bearings and brushes, some of the older ones had to have the
commutators turned down. P-C's routers are really good as well.
Wamsutta
Amarillo, Texas
I believe the half sheet version is the 505. That is one sweet little number right there. Completely devoid of any vibrations when in use.
tarbellb
Oregon
Air Vantage or Bosch GET65N dual action
both a bit more $ than your proposed budget but both hit way above their weight ie worth the extra cost
