Old tool guy
- Joined
- Apr 13, 2023
- Messages
- 3,490
I have a project to place a container on a concrete pad and connect a portable generator. I need to be a little vague because of some proprietary details. The container is like a 20’ conex full of communication devices, it comes with transfer switch and connection points for power, it’s intended to be moveable. The power connection points are camlocks, 5 of them, the generator provides 120/208 4w+g 30 kW. There will be a ground rod adjacent to the container … question is do i need a ground rod at the generator? Renting it from sunbelt, the power cables will be 50 ft.
The grounding instructions are the same for both generators from MQ. Why would you have cam-locs on such a small generator?
