sjoseph316
- Joined
- Nov 20, 2023
- Messages
- 20
Got the black iron pipe run to my heater for propane. It’s a short run, 24” to the wall, 10 ft down to the drip leg and ****** for connection to propane tank line. I used yellow pipe dope only. Connected the tester and filled it to 25 lbs of air. 24 hours later and I lost 3 lbs. I used dish soap and water to try and find the leak but I done see anything. Should I take it all apart and start over or should I try and tighten each connection one by one? Or is there something else I should do to find the leak and seal it?
No inspection needed, I know I’m supposed to have a shutoff valve but my propane guy said there’s no sense in putting one up By the heater since it is 10.5 feet high, instead he said there will be one right outside the door where a regulator will be.
Thank you!!
Thank you!!
