Looking for some suggestions on which type of heat to use. This is a 3 car attached garage. Chicagoland. Last couple of weeks it has been below freezing with extended periods below 0F. Down to -14F a couple nights. My garage was sitting at 24 degrees with a 1500W oil filled heater running full tilt. Everything froze. I ran my Little Buddy heater on High and it brought it up to a manageable 40 degrees. However, the humidity also rose. Up to 65% according to my hygrometer.
I ran some 8s to the panel and picked up a 7500W electric heater. Then I got my electric bill and had started second guessing this idea. This is our first winter in the house so trying to get a handle on the heating situation. We had (4) 1500W heaters running full time (garage, barn, 2 in basement). We used 3022 kWh. Supply charge was $.06848/kWh and delivery was $.04901/kWh. Taxes & Fees avg. to .03625. Total of $.15374/kWh. Working on getting the basement figured out. It was 58 degrees in the finished basement. There are supplies and no returns. Once I run returns it should help and not need the electric supplemental heating.
For NG we used 315 Therms. Avg cost is $.36/Therm. Total cost with delivery and taxes avg. to $.705. We have 2 furnaces, I Set to 68 degrees avg. I drop upstairs thermostat to 66 during the day then raise it back when we get home. I honestly was expecting the gas bill to be astronomical and it wasn't bad at all.
The heater is just to keep the garage at a manageable temperature. Maybe 50 degrees. I can do the math to figure out an hour of run time on the electric heater. $1.15/hr. I just don't know how much it will actually run to figure out the monthly cost.
If I do a 30,000 BTU gas heater, @ $.705/therm, that is $.21/hr to run. BIG difference. How much does a fan forced electric heater need to run vs gas to maintain the same temperature? Would like to note, last year our NG was closer to $1.20/therm (up from avg $.68). Even at the avg. double what it is now, it's still 1/3 less than Electric. Right now I think it's way below the average.
Obviously Gas is cheaper to run, but I have the electric ready to go with the heater. Trying to determine if it's worth the effort to go to a gas heater if it's just to keep the garage warm on the really cold days. This week it averaged 42 degrees in there with no heater running. It's been warmer outside, avg. 33 degrees. Do all ventless gas heaters produce excessive amount of moisture like the Little Buddy? I am toying just putting a propane ventless heater instead of NG so I don't need to mess around with running a line to the garage. It's approx $1/lb of propane here. Or, just slap the electric heater up and call it day?
