Question for the literal tool polishers
rslaback
Westcentral Wisconsin
Found an interesting square/center finder in some of my dad's old tools. I gave it a quick polycarbonate bead blast to get the rust layers but I'd like to get it back to being able to read the ruler scale.
What's my best next step? Electrolysis? Sandblasting? Scotchbright?
Anything too abrasive will reduce the depth of the markings, so be gentle. I would have started with knocking off the loose rust, then gone to electrolysis. Cleaning up after the e zap is a burgundy scotchbrite. Trying to remark the lines is always a challenge for me, trying to find a black that will stay in the grooves is the trick. Nothing has worked well so far. I don’t think you can bring them up without additional marking.
I have the 3M radial bristle brush, that I prefer over wire wheels for trying to get a polish.
Shiftless
East Bay SFO
Once the steel is smooth, I have used black magic markers with some success. Fill in the marks and then remove the excess blackening with fine sandpaper like 600 grit. If there are pock marks from rust pitting don’t do that.
I do also have some evaporust if that would be better.
The Evaporust would leave a dull gray finish requiring scrubbing under warm water with Scotchbrite also. The darkness in the grooves might benefit from less diligent scrubbing.
KSJeff
Andover, Kansas
I've used black nail polish to some success with detailed markings. I use a small brush and try to keep the paint as precise as I can. Don't use the brush that comes with the polish. I use orange on some of my gun sights and it's pretty resiliant to oil/cleaning agents.
dnschmidt
Phoenix, AZ
Do whatever to get the rust off but for highlighting the markings the best solution I've found is signpainter's paint or what we in autobody call pinstriping paint. One Shot is the brand that I use. Just smear it on with a rag, brush or whatever and wipe off the stuff that stays on top of the recesses. It's a slow dry oil based paint so let it dry and you're good to go.
What is your wait time between smear and wipe? I just tried that over the past summer, and I got no adherence in the grooves.
Been sitting on that can for a few years, finally got the time to try it.
dnschmidt
Phoenix, AZ
I find it doesn't matter so the sooner the better. What does matter is what you use to wipe with. I use a piece of an old tee shirt on a hard block. Well, actually a piece of MDF, with the idea being not to have any fibers get into the groves I'm trying to fill. A HINT: don't use a microfiber towel or it will remove all of the paint from the groves as the little fibers get into the groves.
  • Like
Reactions: RTM
4x4Pete
Stroud
Clean however you can. Filling in the marking can be done with Testor's model paint. Wipe off immediately with one of those triangular sponges that women use for make up. This is a motorcycle control we restored. IMG_23081.jpg20210711_111811.jpg
larry_g
oregon
Cleaning precision tools like that I use Hoppes #9 gun cleaner. For rules like that I use some 1000-1200 grit abrasive on a stiff backing using the Hoppes as a lube. With gentle working a lot of times I can save the black in the markings and come up with a nice satin finish in the steel.
lg
no neat sig line
CGarage
United States/Switzerland
lg
no neat sig line
Abrasive as in sand paper?
budget76
I've coated them in a spray paint, then taken a random orbital or sanding pad to sand off everything. cleans it up fairly well & leaves the recesses easier to see
its an option
Maui
Upstate NY
I'd wire wheel it with a relative gentle wire wheel. Should clean it up quickly without affecting the markings at all.
JradM
Alberta
I was also thinking sanding will be necessary. How else are you going to achieve a shiny flat top surface again? Use a stiff backer on your paper so you don't dig in. Cross your fingers that you don't have to sand so deep the markings disappear. It looks to me like you might be ok.
You could try to make the markings a bit deeper in advance - maybe with a carbide scriber. There are other ways to do it, but they might end up requiring an unreasonable amount of work. A couple back-and-forth scrapes inside each line is already going to take a minute.
A low-power engraver with a precision tip might work too, but you don't want something that works too fast. You could use something as a straight-line guide too - it might otherwise be too easy to jump out of the line.
Last idea: Rust Check "Rust Wash" might be more appropriate than Evaporust in this situation. Rust Wash leaves a shiny metal surface when it's done, not dull grey like Evaporust. It actually removes the rust, rather than converting it to a stable state.
Shiftless
East Bay SFO
Scraping with an ice pic or dental tool before painting black would also remove any crud that has built up in those little grooves.
Renegade1LI
long island ny
Polishing can become very addictive, always start with least destructive.
39 LaSalle
TN
A trick I learned from my dad was to rub old markings like that on old squares and such with soapstone and wipe off the excess. Yes, it will eventually need to be reapplied, but it's minimal effort and has always worked pretty good for me.
R
rslaback
That Rust Wash looks like a winner but I can't seem to find it in the states. Is there such a thing as a similar product in the US?
seber
Deep East Tx.
Wet sanding or even dry sanding with appropriate grit will bring it back to the original look. Then add carnauba wax to prevent a recurrence.
