Between 705 & 1200 SQ/FT My Mini Garagemahal
F
fouckhest
Greer, SC
Figured I'd post up my initial impressions of the new Evo chop saw....after cutting some mild steel 1-1/4", 16ga square tube.....THIS THING ROCKS! I see the abrasive saw collecting dust for the foreseeable future
Cart material order was placed at 8am'ish, picked up around 3pm'ish....really like having a Metal Supermarket so close....just wish my local metal scrapper was as close and flexible with hours
Home and unloaded and ready for evening shop time
Untitled
by fouckhest, on Flickr
Saw assembled on temp stand ready for some action
Untitled
These cuts are fresh off the saw, no debur
Untitled
All materials for the frame of the cart
Untitled
Hard to tell in the photo the amount of chips, its not crazy, but there is a fair amount, but I guess that is to be expected with an ~1/8" blade cut width, will be curious to see how it does on the cart with the chip collector/chute
Untitled
Closing thought....it is a bit loud, but not as loud as the abrasive saw and you dont end up with that lingering burnt metal/abrasive smell once done using the saw. Will be curious how it does with stainless steel, but again, I see it being a huge upgrade. (y)(y) Would recommend (y)(y)
F
fouckhest
Greer, SC
Didn't get much shop time last night....wife accepted a new job at work, as did I recently, so we decided to get out of the house and go have a couple beers at our local brewery...
However, I did make some CAD templates at lunch yesterday....realized I was interpreting my math wrong, so the fit wasn't great, as you can kind of see here...but it made me realize my mistake, then drew the actual pieces out on the sheet metal and everything seems like its going to work
Bad fit cardboard, but Good fit on my corners, new saw, muy bueno (y)(y)
53547377474_3c31b99bbc_b.jpgUntitled by fouckhest, on Flickr
Patterns drawn....I realized that when I was calculating everything in excel I had calculated the hypotenuse of a triangle, which I thought would be the corner, but in fact it should have been straight up the center of the bend...so after discovering that, drew these out, and now both my corner and the center line measurements are identical for each pattern which is short side/long side....that may or not make sense...lol
53547045156_f7d721c72c_b.jpgUntitled by fouckhest, on Flickr
F
fouckhest
Greer, SC
Fun weekend filled with checking another project off the list....Saturday started with butchering the Crepe Myrtle in the front yard, hated to do it, but it was so out of control it needed to be brought back to square one....no photos of the savagery to protect the innocent
After that was done I shifted focus to the Evo saw cart....tested out my new metal shears, worked great, then set out to put some bead rolls in the sheet metal for the chip chute....trying to use that tool where possible so when I start making panels for my car they look halfway decent
53552444249_1f928bb059_b.jpgEvo saw cart by fouckhest, on Flickr
Chute tacked up inside the top
53552552865_5ac6ea316b_b.jpgEvo saw cart by fouckhest, on Flickr
Mocked up before final weld...all seemed reasonable
53552303503_7ab28903dd_b.jpgEvo saw cart by fouckhest, on Flickr
Added some corner gusset/mounting plates for casters
Evo saw cart
Evo saw cart
Took it outside for some cleanup, hit it with some roll bar and chassis paint, then a final top coat of bed liner
Evo saw cart
Evo saw cart
Nutserts for mounting the saw
Evo saw cart
Project complete!
Evo saw cart
In the name of continuing to evolve the work space, the hydraulic press got moved so the saw could be closer to the work bench, seems like it will be a good spot with plenty of room on either end for working with long(er) pieces of stock when needed
Evo saw cart
F
fouckhest
Greer, SC
@fouckhest
Can i pick your brain, I am needing to remove the stupid soft-touch material that VW used in the Mk4's do you have any tips or tricks?
To be honest, I've never found a "silver bullet" method, I've used goo gone, rubbing alcohol both with a green scotch bright....typically it is just an annoying/cumbersome process.
But when you do finally have it all removed, a good cleaning with this soap/wash and then use the SEM trim paint, it will look like new
Well done on that stand!
Thanks!
F
fouckhest
Greer, SC
My latest order from JMD tubes showed up yesterday....so after my close to last work light day of this week, went out to the garage, eyeballed my last bend, took a leap of faith, marked it, cut it, fit it....much to my delight and surprise, it fit like a glove!
The leg on the 180 was ~1" too short, not a big deal, that will never be seen....this was fit up...if you look closely you can see where I taped the 1/4" deepwell to the runner below to ensure access to that last manifold flange nut
53558745791_4b4bce604e_b.jpgUntitled by fouckhest, on Flickr
Decided it was close enough for gov't work and tacked it up....very close to calling the headers done and moving onto the next steps, which I am currently ruminating on! lol Which I should have plenty of time to do next week while traveling/onboarding for the new job
53558745811_b2dfc6cb8d_b.jpgUntitled by fouckhest, on Flickr
53558745831_f1b500ff63_b.jpgUntitled by fouckhest, on Flickr
53557887897_40b3957fd7_b.jpgUntitled by fouckhest, on Flickr
Lastly an over head shot....symmetry isn't perfect, but I am going to say its a "B" for a rookie! :cool:
53558944353_d7de46d314_b.jpgUntitled by fouckhest, on Flickr
MrPink
Bridgeport,MI
Thanks!
Goo Gone ftw these were my trial prices, I have a nice satin black paint here too.
F
fouckhest
Greer, SC
Headers are looking great. I would love to hear how this thing sounds.
Hopefully one day sooner than later I'll be able to post up a video! :cool:
Awesome, they look good! Good bath, some SEM trim paint and they will look better than new!
F
fouckhest
Greer, SC
Got invited to a super cool event last night at our local Audi dealer.....some may know that there was an event out in CO a couple weeks ago called FAT International (https://fat-international.com/) where a bunch of cool cars did cool things on ice/snow, LOL
Anyway, the two Audi Pikes Peak cars left there and where heading to Amelia Island for the concourse this weekend, and they stopped at our local Audi/VW dealer for a little show/tell....not only were the cars on display, got to hear some cool stories about them....they also took them outside and ripped them up/down the road a couple times....figured this group would enjoy :beer:
53561516398_2fed9dd53c_b.jpgUntitled by fouckhest, on Flickr
53561318866_5c36237bce_b.jpgUntitled by fouckhest, on Flickr
53561762705_b8f7e561e1_b.jpgUntitled by fouckhest, on Flickr
F
fouckhest
Greer, SC
The newer one was quite tame rolling out... the return pass was a nice surprise!
Is there a post where you explain the start/scope of the V8 project or where the idea came from? Crime of opportunity with the motor choice or?
I'm sure between cold tires, cold tarmac, old school turbos (late spool), crowd, etc....that was the "comfort" zone.....either way, the red car certainly made some great sounds
Widebody car, this version is being documented over to grassroots motorsports....that gives some history, and a few more photos than what I typically post here, plus it is focused on the build, not in/out with house projects, that I post here
customh
East Bethel, MN
Thanks for the buildout link!
FYI the link is missing the .com in there- fixed it in my quote.
F
fouckhest
Greer, SC
Back from a whirlwind of a week with my new company and boss for on-boarding. Its nice to start someplace, get involved immediately, certainly solidifies my decision.
No much in the way of updates....I had secretly hoped that I was going to be able to come on GJ today and post that my wife and I were under contract on a new house/shop setup.....but that fell through...I'll save the gorey details, but there is an older brick range on 7.5ac w/a 60x60 shop not even 1mile from us that has been on the market for almost a year, we decided after looking at it two weeks ago (and talking with the realtor) to make an offer....we hit them at 2/3 the ask price, which is actually a very logical spot, but after 3days they said it was too low....oh well...
In other news, trying to get the last remnants of the laundry addition wrapped up, which will be the snowball of the back of the house siding, then deck, then new gate....so tonight I started ripping down the old siding...still need to take the old old grey siding off....job for tomorrow night after a dump run tomorrow.
Green vinyl is out...going to be replaced with board and batten
53581204882_2c9ea8e211_b.jpgUntitled by fouckhest, on Flickr
Now for some small shop things....finally bit the bullet and picked up a legit welding hood...i have to say, I am very impressed and I should not have waited this long!
53582071311_c0712d15e4_b.jpgUntitled by fouckhest, on Flickr
Put it to the test Sunday morning...helped a buddy out with an o2 sensor bung welding job....told him to mark it, I'd stick it
Friend/customer marked two locations, I told him I like the straight section better for more consistent flow/reading (its for a stand alone ECU)
53582295833_21fdca5a37_b.jpgUntitled by fouckhest, on Flickr
Hole drilled
53582516535_1307803ac1_b.jpgUntitled by fouckhest, on Flickr
Finished product
Had to get my argon bottle refilled today, so I am back in business and ready to dive into the next phase of the widebody car project :cool:
MrPink
Bridgeport,MI
I have to have another 02 bung welded in too. have to run my rear 02 sensor still lol.
Good work, the sentinel hood looks awesome, I have a cheapo HF one and it functions but I really want a better one.
F
fouckhest
Greer, SC
o2 sensors are good practice projects
I have a HF helmet that I'll keep around, along with my original miller fixed shade. I'll be curious to try the new hood with the MIG, but will definitely be putting a new cover on to keep the TIG one nice
MrPink
Bridgeport,MI
I am having a friend of mine tig it in as it's on stainless, and i have not welded stainless, or on exhaust for that matter lol.
F
fouckhest
Greer, SC
I've been welding stainless with my MIG, using 98/2 Argon CO2 mix and stainless wire. Seems to work OK.
Oh nice!
I usually disclose that "its possible" because most wont typically have stainless wire or that strong of an Argon mix. That setup sounds solid for being able to MIG stainless!
Bob Heine
Boca Raton, Florida
@fouckhest, I had do do a song and dance to get that mix from the local welding supply place. I tried TIG with 100% Argon but I zapped myself a couple of times feeding the stainless rod into the puddle. A sweaty stump inside a prosthesis socket makes a decent conductor, as does the braided stainless cable that actuates the stainless hook.
