Milwaukee Power Tools Deal Permathread
Tundra1
I think it's fairly restrictive on what qualifies. From what I remember, you have to place specifically qualifying items in your cart and the discount automatically applies. But it can be a pain finding items that qualify, it's not all Milwaukee tools that get the discount.
2manytools
Mt Pleasant, MI
Does anyone know how to make this work? Getting no joy either online or in my local store.
Apologies. I went back, and it doesn't kick in until 3/26, or maybe 3/25.
It was one store that flipped their sign early. Told me I could buy, and they would re-ring later on. I was hoping for the $175 just off my saw 😞
Rusty67
LA, CA
Not sure if that BMSM is still active? This is the BMSM I see online from HD right now:
Maybe in store is different? Not seeing the chainsaw in the current offering.
Odd-job
I see the track saw is part of the BMSM from HD. Is this a first?
A lot of stuff isn't worth the BMSM like the router and jigsaw IMHO. Those go off for $100 or 50% vs the 30% off max on BMSM.
2manytools
Mt Pleasant, MI
I posted above, but the OPE BMSM doesn't start for a couple more days. One store put the sign out early, and I didn't catch the date
Rusty67
LA, CA
3x M18 12.0 batteries for 399 is back. I think someone was looking for these recently?
The 4x M18 6.0 batteries are also back at 359:
Some other stuff on special buy of the day but nothing that interested me.
bigboost
Jacksonville, Florida
Nice.
The 3 12's is a pretty good deal.
The 4 6s is pretty terrible.
PAN FRIED
Anyone know of a really good M18 Sawzall Deal? With battery(s) and charger or without? Thanks
webscrounger
Midwest
Not up on everyone's current pricing but Clark's has a a couple Sawzalls on sale that look reasonable at $135.
vwpieces
Hills, PA
The_Inspector
The Netherlands
Any of you guys have experience with the 90 degree die grinder? Is it possible to use it as a Dremel? I know you can put in a 1/8 chuck and use the Dremel/Rotary attachments, but how does it affect precision.
Blackwolfe
Sunset MI
I'm considering getting the Milwaukee M12 12-Volt Portable Inflator No. 2475-20. Home Depot has it available for $99.00. Is that a good price, or is it frequently available for less? Thank you.
BroncoAZ
I would steer you towards the M18 inflator if you are planning on using it frequently on car tires. The M12 is great for bike tires and acceptable for car tires, the M18 is larger, but better. That being said, $99 is a pretty standard price. Ebay has some new in box units for $90, or pulled from kits for $84.
bigboost
+1 for go ahead and buy the M18 version, it does everything from inflate our giant paddle boards to topping off my RV tires to 80psi.
It's one of my most used tools, we have a lot of inflatable things, bote couches, paddle boards, etc.
06 DIESEL
Middle River, MD
My only complaint about the M18 inflator is that it pumps so fast when using it for smaller tires if on the preset that even with it doing its checks it will not inflate properly and do a bunch of short cycling then shut off. I use my M12 for smaller tires and my M18 for larger tires. It will inflate without issue to 100 PSI on my trailer tires. Once 6.0 battery will take four tires from 70 to 100 PSI on a full charge.
mrvm
PA
I own both M12 & M18 and that’s exactly how mine are used. IME the M18 was inaccurate for topping up tires to clear the TPMS. Never an issue for the M12 to top up accurately and consistently. The M18 is much better for bigger inflation jobs.
ou812zx
Like others have said, the M12 inflator is a decent little light use unit. I used the **** out of mine until I got the M18 inflator. The M18 is far superior, and works about 3x faster. It is noisy, but an effective and very useful tool.
bigboost
Maybe I'm wrong but I've always figured that's how it's supposed to work, much like all the air pumps at gas stations, they will head towards a target PSI, and then when they approach the target, they start pulsing as to not overshoot the target PSI.
I set the PSI and walk away from everything I inflate and always arrive at the correct PSI.
Blackwolfe
Sunset MI
Thank you for the pricing info on the M12 inflator. And everyone for their input.
Will most likely use the M12 as a light duty inflator for topping off car tires, bike tires, and sports balls. I don't have any M18 platform tools or batteries and have been trying to avoid adding that platform. I do have a small compressor for larger inflation needs. For smaller needs, including topping off car tires I've frequently have been using a bicycle floor pump, but thought I would step up to an inflator
mikeinri
Interesting, I've had zero problems with my M18, and use it on three vehicles with TPMS (plus an ancient RV).
@Blackwolfe: I hear you on resisting the different battery platform. I feel the same as you, except I have M18, and keep fighting the urge to buy M12.
Mike
bigboost
Mike
Yeah, don't think he realizes it's supposed to cycle on and off or his is broken, one of the two.
I resisted adding M12 to my M18 collection and TBH I'm mad I waited so long, I prefer most of my M12 tools to my M18 unless it's something big like a 1/2" Impact lol.
Not really sure how the science sciences but I have several M12 tools that are stronger than their M18 equivalents which makes zero sense to me.
Back to deals.
rvieceli
Illinois
I had both the M12 and the M18 inflators but let my son keep the M12 one that last time he borrowed it. The M12 works fine just takes longer if you are going from really low to full on bigger tires.
I find that the M12 inflators gets to the target PSI and stops while the M18 inflator generally goes slightly over the target and then bleeds off air until the target is reached.
Ron
06 DIESEL
Middle River, MD
Mike
Back to deals.
Yes I realize that this is how the system is supposed to work. Just stating that on smaller tires the M12 works better.
rvieceli
Illinois
rvieceli
Illinois
Here's a Milwaukee pack out deal
Rural King looks like in store only My area has this but don't know if all the stores do .
Spend $100 in Milwaukee pack out stuff get an instant $25 off.
Here's a link to their store locator. They are in 13 states mostly in the Midwest.
Ron
todd_fuller
The pricing on the super sawzall is cheaper than eBay pricing. Nice find.
monkeyplasm
TN
Been thinking about that one. Give us a report once you get a chance to smack it around a bit, please.
