Linked to the brochure tab in the spreadsheet. Thanks Cliff!Might as well add this Franklin info too.
Here is a vice from Italy.Hier ein Schraubstock aus Italien.
FZA MG/10 80mm Backenbreite.
Dieser Schraubstock wird noch produziert. Es besteht aus Guss Eisen. Nicht aus Guss Stahl.
Der Schraubstock ist gut und präzise, die Backen sind wendbar. Die Spindel ist verdeckt. Die Führung ist sehr präzise. Der Drehteller ist robust, aber eher schlecht konstruiert. Kein deutscher Standard.
One more pictureNoch ein Bild
Awesome you can read Italian Outlaw. Thanks for the interpretation.Here is a vice from Italy.
FZA MG/10 80mm jaw width.
This vise is still in production. It is made of cast iron. Not made of cast steel.
The vice is good and precise, the jaws are reversible. The spindle is hidden. The guidance is very precise. The turntable is robust, but rather poorly constructed. Not a German standard.
I can't read Italian nor much German (which is what it is) (1-1/2 years in HS did not stick...)Awesome you can read Italian Outlaw. Thanks for the interpretation.
Thank you for translation ! I think it could translated automaticly, but it wasnt.
Only if most of the page is in a different language, then chrome will offer to translate automatically.Thank you for translation ! I think it could translated automaticly, but it wasnt.
Here is a small Dawn "dawnette" made in australia, clamp on 2 inch jaws
I can see why someone would remove the pipe jaws, they are so massive they limit the usefulness of the vise except for clamping pipe.12vx2: I can't identify the maker of that vise but here is some information on the type of vise it is. It's a combination vise (missing it's pipe jaws) based on this 1865 Dart patent. Several other makers used that style too. Notice that it has through-the-bench mounting. I'd say it's worth the asking price just for it's rarity and I already have one of that type. I hope this helps you.
Missing pipe jaws on the older US style combination vises seems to be very common.I can see why someone would remove the pipe jaws, they are so massive they limit the usefulness of the vise except for clamping pipe.
Made for the railways
