15 degree offset DBEs in metric?
lardy1
I have some nice lengthy ones in SAE but don't see a lot in the places I've looked for metrics. Snap-On has nice ten degree but just not even a chance I can justify that cost.
These will be for home shop use. Suggestions?
Fedwrench
Valley of the sun
Proto or Blackhawk on EBAY. May have more than 15 degree offset but, the Protos are finished very nicely.
Capri and Genius have really nice, long pattern DBE wrench sets but, they're zero offset. Great for reach and applying extra umph.
2ndGearRubber
Pittsburgh
I have a Williams set I made from singles. They work good when I need them. Normally I use a deeper box design. The box ends are a little chunky, but it hasn't caused me any issues
L
lardy1
It seems Craftsman made some in the raised panel design. Those can probably be patched together over time but I did that with SAE Husky (New Britain) fairly affordable but the Craftsman on Ebay is ridiculous. I really don't want to go that route but haven't ruled it out.
The Williams are also outside my budget, unfortunately.
Apparently this style isn't very marketable because, other than the zero offsets, the Asian brands don't seem to be offering this. Or many options in long pattern combinations which is where my thinking began but the open ends are beyond redundant.
Thanks guys.
KnurledNut
n/a
VIM DPW100. These are extra-long. Skips 9 and 18.
I dont have them, but I would consider if I needed a set.
Could be had for around $100 if the cards are played right.
Pic borrowed from public images:
drtyler
Amazon has a Wright 13 x 15mm for about $27. Not chrome plated though.
Wright double box wrenches are trash.
Steve_P
There was a thread on this a few months ago, specifically looking for a Snap On substitute. After looking at all of the options in the thread, I went with the Stahlwille 23 linked above. There are all sorts of options for long 0* DBE, but OP specifically said 15*. Yes, the Stahlwilles are 10*, but that's closer to 15 than 0.
Fedwrench
Valley of the sun
I have the VIM drain plug wrench set. They are unique in that it's not just boxed end that's angled but, an inch or two back is angled. They're at work so, I can't show you what I mean. Really nice wrenches :thumbup:
nadogail
Coronado, CA
Many times when i wanted a unique wrench for a special purpose i made one from a standard wrench with an Oxy - Acetylene torch and a grinder.
