Well I hooked it up today.
Since it is only a temporary connection (will be placed in the shop when it is done later summer) I gave some PEX a try.
I had an existing run to a hose drop from my previous compressor and I needed to connect the new compressor to the drop. So instead of spending a bunch of money on a custom 1/2 hose I picked up some 1/2 pex and 2 shark bite connectors from home depot. They worked like a champ!
Boy this thing puts out air! I sand blasted for about 1 hour and it was cool to actually have the compressor kick on and then kick off while I was still blasting. I can now go to a larger orifice and even have more blasting power, however, I might not even do it because as fast as I could move the gun it ate the paint and rust off of what I was blasting. (this is how it would do it for about the first 30 seconds with the old compressor)
It was actually a pleasure to blast, instead of getting frustrated because you can tell the blaster is down on pressure and have to wait.
I blasted the swing arms on my two post lift that is going in the new shop. If I had to do this with my other setup it would take about .75 hours each. I did all four in that amount of time.
It is also fairly quiet, as far as a compressor goes.
So far so good.
I think the next thing I am going to rig up a franzinator set up like yours Brad, I just might skip the cooling tub for now and just do the pipe trap.
