02Xterra
Lynchburg, Va
Last night I finished the paint and installed the metal rack I built. I got tired of having metal all over the place, lately a lot of it stored on the car lift to keep it out of my way. 8' 4" tall and just over 16' wide. This is as nice as it will ever look. lol. Today I get to start loading it, fun fun. Top of the outlets are just below the tops of the #4 rungs so they should still be assessable when steel is on the rack.20240409_181356.jpg1000010149.jpg
That's a nice rack!
admranger
Las Vegas, NV
Inspected the suspect bolts on the Jeep. Used my finest chinesium micrometer and the bolts were 0.004 inches different in length. Now, maybe they are both stretched too far but looking with my calibrated eyeball, they look to not have any "necking" going on in the gap. Could be hidden though. Grade 10.9 bolts. I should take one out and go to Fastenal and just buy two replacements and DIY it. Jeep has the bolts priced at $3.65 each. I can afford that.
Also rewired a motion sensing 4' LED shop light. It was wired into the motion sensor switch for some of the garage lights. Problem was the Jeep is larger than the previous car and it's hard to see the edge of the garage wall and I don't want to drag the mirror over the stucco at night. The other car shields the headlights of the Jeep from triggering the motion sensor. Hopefully, due to the location of the shop light, it'll trigger when I pull the Jeep up. That old motion sensor light is the only thing that's tough to trigger nowadays...IMG_5594.JPG
Fix Until Broke
SE Wisconsin
Are those 18” extensions?
I did not realize that they made them that long - here I’ve been cobbling together every available extension I have.
Snap-On make a 36" long 3/8 Drive - works well for bellhousing bolts with a swivel socket.
Yes it's expensive, Yes it's worth it not having to put 5 different ones together and all the extra fun that comes with it...
Tekton make a 24" one --> https://www.tekton.com/3-8-inch-drive-x-24-inch-extension-sha11124
mrb1
Miami County, Ohio
Almost replaced the alternator on the old backup '08 Cobalt. The two day free shipping (Amazon) on the replacement unit was supposed to arrive yesterday (Wed) at 4pm. Come 4pm no alternator. And the tracking was changed to 6pm, then 8pm, and again to 9:45pm. I knew then it wasn't happening. Finally one more saying 10:15pm :ROFLMAO: This morning showing 4pm again. Raining all day here, so might as well shop-vac and clean the inside and windows.
Pictures are from the parts of the job the Youtube guys edit out while they're cussing and sitting down for a beer and a smoke. Or at least I was. "Just pull her out and drop the new one in",,,sure. Out of heavy duty, long zip ties to hold the radiator hose back, but the ratchet strap worked great. Also ground off the corner of a plastic bracket for other wires with the Dremel that was in the way. Bet your ***, if it don't show up today I'm starting a new thread about it 🤪
whateg01
doo dah, kansas, usa
welder4956
Birmingham, AL USA
I have noticed this happening more frequently lately with Amazon. Usually, I actually need it the same day but can tolerate waiting till the next day. They offer next day delivery if you order within the next few hours, then it does not arrive on time. Not sure if they are doing this intentionally to increase sales or it is a problem with their delivery system. But I find myself looking locally more for in stock items when I need it the same day or next day, so it is actually costing them business in my case.
mrb1
Miami County, Ohio
Waiting on the alternator↑↑↑ I figured I'd get something that's been bugging me for a long time. Bench and Delta grinder are 15 years old. Very "solid". Grinder for occasionally homeowner use. Vibrated just enough to randomly drop something off the pegboard, or something else walk off the bench onto the ground. These silicone potholders (trivets) from the kitchen looked promising. Heated up a similar size bolt and made four pieces. 100% better. Barely hums now, and almost zero walking on the bench.
ZRX61
Solar Blight Valley, SoCal
Squirted some seam sealer* into two small cracks on the F350, one each side right at the rear of the drip rail. Luckily it's white, as is the F350, so pretty much an invisible fix.
*Berkland, the good stuff, not some **** from Lowes etc.
Also gave a bit more of the underside a spray with degreaser & hosed it off. Right side of oil pan & transmission pan now looking quite spiffy, as are some parts of the steering & suspendies.
In a perfect world I'd get it up in the air, get gussied up like an Alaskan crab boat deckhand & give the underside the benefit of degreaser, soap & a steam/pressure washer.... Whereas right now I slide under it, spray LA's Totally Awesome, agitate with a sawn-off Horrible Fright 2in chip brush & then hose it off from the side. Which works quite well for the right side owing to the sideways slope of the driveway, but means I'd be laying in a puddle on the left side... ******. Will experiment with the creeper tomorrow (or attempt to back it into the side driveway...)
welder4956
Birmingham, AL USA
Made a mess cutting up some 16 gage sheet metal to make a storage area under the workbench. Left scraps and grinding debris for cleanup tomorrow. Only had a few hours this afternoon due to doctor appointment and lab work this morning. Tomorrow will be more of the same, except we have a funeral to attend in the morning.
kaymccampbell
Upstate New York
backupbeeper
I can't find the "exact one" I used, but here is a similar one:
(Amazon)
1Pcs Automation DC 12V Time Delay Relay Module LED Display Digital Delay Timer PLC Delay Time Control Switch 0.1Sec to 999Min Adjustable​
Speaking of timers ,
I need one that when I hit a switch , it turns on power for a half second or so and then goes off ,
I need this to run parallel with another device that stays on as long as yoire holding the button .
So when I press the button one item gets power for a half second and then it switches the power to a second device and keeps it as long as the button is held .
Snip's
Controlled explosion of my Delta Doerr electric motor....
The bearings need replacing... Crunchy...
Nachi 6203-2NSE are in route and expect brown truck delivery tomorrow...
Since they were ordered from the Jungle site and claim to be COO Japan, I'll be running it by my WBA 2.0 app World Bearing Association
Nice free app that I've used on some bearings I ordered from McMaster-Carr that proved authentic...
Can't be too careful... It's the wild wild west out there with fakes...
cosmokenney
Loyalton, CA
After having this kind of winter...
I decided I was done having my snow blower feet getting pinned to every little crack, rock and lifted-by-tree-roots-bump in the driveway. So I welded on some skis. Was thinking we were going to get one more big storm, but all we got were a few with an inch or so that melted by the next day. I'll let you know next winter how these work out ;-):
Magnum440d100
Indiana
In a bit of serendipity, I got this mower.
Well, yesterday, I went and got this mower for the rear end for the one I’m putting together. $45 for the rear or $100 for the whole thing. I bought the whole thing. IMG_3714.jpeg
Well, he had another one with a 6 speed. So I paid him $100 for IT. Just because. IMG_3721.jpeg
Well, it turns out it’s the one I got from @bugnut!
The sticker residue on the back by the decal, plus a tubed right rear tire I put in before I sold it.
It made its way back. I’m gonna fix/keep it now haha
Dunno what’s wrong with it. It ended up being such a sweet runner. When I get a chance, I’m gonna tear into it. It would be nice to get it mowing again! I kinda missed it.
whateg01
IMG_8332.jpegChecked tire pressure on spare for my wife’s van. I haven’t checked it in years and I’m glad I did. The tire pressure was down to 8 so I filled it up to 40.
Did you check the tire to make sure it still looks ok? That's still not the same as it being ok, of course, but it's falling apart, that would be a good sign to replace it.
admranger
Las Vegas, NV
Send that message to Jeep Corporate (preferably legal) and see your turn get prioritized...
So, ironically enough I got a call yesterday from the dealer and the parts needed for the upper control arm pinch bolt replacement were in. I had them installed in an hour this morning at the dealer and I'm good to go.
Good thing I had washed it yesterday so I could bring in a clean vehicle. :cool:
GrayFlattop
Chicago
Repaired an old pressurized water fire extinguisher (broken dip tube, my fault). Really a spare unit, but back in business with a dremel and some epoxy. I use this one to make my bride practice every few years.
Cleaned up a bunch of old pipe fittings and hardware in the ultrasonic cleaner and put them away where they belong. Tossed anything marginal.
Did a little troubleshooting on the air compressor (small air leak, but enough to drain the 80 gallon tank overnight) and determined that the automatic drain mechanism was the culprit. Eh, I think I’d rather eliminate it than repair it as I now have a good ball valve on the bottom.
Cleaned up some garage sale finds, then put a scotchbrite demurring wheel on the smaller bench grinder. Called it a day.
Nothing outside except to get some line to tie a tarp down. We have a couch outside waiting for bulky waste PU day in a week, and big rain due tonight/tomorrow so I don't need it 2x heavier with water...
Getting closer to moving the inside workbench to its new home. Probably tomorrow...
