The Everything 3D Printer Thread
purplezr2
Central MN
so far its cranking away. the spool holders on the AMS are a little wonky but nothing that isn't usable.
for a first time user or second machine I dont see why its not a fantastic choice.
Do it take regular sized spools, I haven't looked that much into it.
jeepxj
yea its more so about the inner diameter of the spool. my white PETG amazon china stuff was falling off. im sure someone makes adapters but not important to me yet.
jeepxj
damn one of them has a no go heat bed. 0C. did the troubleshoot guide. reset all the connections. still nada
moab11
Thunder Bay, Ontario
Experimented with some PLA Glow from Bambu Lab, print quality was ok, had some defects on the bottom side of the "weaves" but that may be a tuning issue. Otherwise this is pretty neat stuff.
Also got the IdeaFormer build plates from amazon and have been very happy with them. Running them at their recommended temp of 60c (default for Bambu lab is 55, but my printer seems to like an extra 5c on the plate temp) parts are sticking great and coming off easily afterwards.
XJSuperman
Central Iowa
Mine likes 60 as well.
With the go-fast settings and fuzzy skin I attempted a large rectangular lid for a printer toolbox. Outside came out ok, but the walls inside of the lid were horrible. Lots of peeling, delamination, and waves. I scraped it down with the scraper and called it ok, but it was pretty bad. I think on those longer flat walls I'll need to retune.
ptt49er
Rock Hill, SC
We had that issue w/ one of the X1Cs at work, we were able to take the heat bed apart and solder the connection back to the board. After working w/ the Bambu CS team to get a new one on the way. Now we have a backup.
You might be able to do the same, getting to it was the hardest part.
jeepxj
yea I pulled the heat bed once already to set connections. gona go back in and try again.
jeepxj
more heat! to keep up on the long straights needs to run hotter. or slow down the speed.
moab11
I'm guessing you are talking about increasing the temp of the hot end?
I'm finding that the default bambu settings are all on the cool side, bed temp can be 5-10c higher, the Aux fan on the X1C is always set too fast and I'm beginning to think the nozzle temp could be increased a bit too, all of this at standard speeds.
jeepxj
do a temp tower print. really helps dial things in. i'm burning about 1.2-1.5kg a day per printer with my current settings. the factory nozzle heater is running just at the edge. if i take the temp from 258 to 262 it errors that i cant maintain temp.
Poolshark314
MD
The aux fan is useless. I have found it causes more print failures than it actually helps. leave it off and you'll be better off
cycle61
Middle of Oregon
Several months ago I was struggling with print quality issues on my Prusa Mk3. Found a resource indicating the nozzle and cooling fins may not be touching inside the heat block because of poor DIY assembly (guilty). This results in filament oozing out between the block and fins, eventually clogging things, screwing with heat transfer, and generally making a mess. @slodat sent me home with a kit containing some upgraded pieces, and today I finally got around to installing the new setup.
Original grossness
The new hotness
And the first layer looking pretty good!
jeepxj
Problem: I'm lazy. I dislike how long it takes me to cut these foam strips to 75mm.
solution 1: make a jig:
slide in. cut perfect length every time. place in bin.
placing in bin. ugh. too much work. lets over engineer a solution.
behold. the most over done foam strip cutter. with auto kick.
foot pedal operated. using the exhaust from the pedal to kick the foam strip to the bin. lets me use both hands to manage foam roll coming in.
double ram to keep the razor blade in line with the cutting surface.
kppolich
Eastern Iowa
mv213
Dallas, OR (the OTHER "Big D")
draco_1967
Utah
I can't believe I waited so long to get a PEI print surface! I've been printing for 4 years now on the same Ender 3 V2 glass bed. I was never able to get anything to stick to the textured side of the glass, but the smooth side worked fine with a little glue. But it was a pain always having to clean off the residue after each print.
Yesterday, I installed a PEI plate, leveled it (after resetting the Z limit switch), wiped it down with 99% IPA, and hit print. Perfect adhesion. When the print was done, and the plate cooled, it popped off before I even removed it from the printer! What have I been doing with my life?!
kppolich
Eastern Iowa
Here's the STL for the Vyper filament guide I remixed.
slowtwitch73
Hellgate
^^ if it is, I'm wondering why the printing wouldn't be more a prototype tool, and then get finalized product versions injection molded or whatever...
There was guy here before 3d printers were a thing, who invented the french press to go mug.. he ended up having Aladdin make them them for him, and then he sold out for a pretty good sum.
jeepxj
Genuinely curious about this. @jeepxj is that the main thing you're selling? Must be crazy successful to go in $7k on filament. That's pretty amazing.
yea thats whats paying its bills. the main issue at hand is print weight. the larger stuff is pushing 700g a print job. i'd guess 60-70% of what i'm selling is in the 500-600g range.
1kg spools are an absolute joke. latest order is all 5kg spools. I'm going to experiment with some 10kg spools.
jeepxj
priced it out already. i'm not selling tens of thousands to hundreds of thousands of units. it doesnt pencil out.
printers ROI in under a couple weeks. they are hands off. I can make design changes as much as I want with no mold cost.
