Gantry crane/car lift
Blaircobb
Has anyone ever seen or heard tell of a gantry crane that doubles as a car lift. I'm looking at moveable lift ideas and thought maybe building a gantry crane that would have the same components as a 2 post lift also. When you use the lift either flip up the caster wheels or put legs down for stability. Ceiling clearance isn't an issue but floor space is.
Renegade1LI
long island ny
I have an aluminum gantry that is easy to roll around and transport, very handy. I can break it down and load it in under 10 minutes if I need to bring it for loading and wide enough to clear my dually.
dave*99
Coastal NJ
I'm having trouble picturing what you have in mind. For example, a 2 post lift carries load on the columns. A gantry crane carries load on the beam.
What are you proposing?
b-dog
Lakewood, CO
I have a gantry; sounds sketch AF and I wouldn't work under a suspended load. You can get some portable car or truck lifts. Roll them into the corner when you're done.
Ders
My yard
What type of magic engineering will it take to keep the bottom of your legs from splaying out from the load of the car? I just forsee disaster but maybe I'm missing something.
Blaircobb
When lifting a car the frame of the lift would be sitting on the ground not on the dolly wheels. And the beam at the top would be adding support to keep everything square.
CraigStu
Blacksburg, Va
So that takes care of sideways movement at the top. But think of a car on a 2 post lift where the lift arms extend inward 1-3ft to contact the car. That leverage would push the bottoms of the posts outward. So how to counteract that? How long will you make the bottom legs so the thing doesn't tip forward or back if you don't get the car CG just right? I am sure this can be done but there is a reason why there is so much emphasis on concrete strength and depth specs as well as fastener specs for a 2 post lift.
whateg01
doo dah, kansas, usa
I see it. A 2 post on wheels with a beam across the top. I like the idea.
Every time a mobile 2 post gets brought up, somebody comes along and explains how it can't be done because it would be unsafe and the tops of the columns have to be able to move and if it was doable companies would do it, blah, blah, blah. I like it too!
whateg01
What type of magic engineering will it take to keep the bottom of your legs from splaying out from the load of the car?...
When lifting a car the frame of the lift would be sitting on the ground not on the dolly wheels. ...
... That leverage would push the bottoms of the posts outward. So how to counteract that?
A crossmember that connects the bottom can sit on the ground in use so a vehicle can drive over it. The same crossmember can be used to help keep the columns square.
The same consideration goes into the legs of a gantry except that the cg is automatically going to stay between the vertical members since the loss is dangling. For lifting a car, or whatever, on the arms, the legs only have to extend as far as the arms do fore and aft, plus some margin. Heck, make them as long as the potential vehicle if it makes ya feel better, but that's overkill.
whateg01
I love it when non engineers try to solve engineering problems with mumble jumble instead of free body diagrams and numbers.
Me too. It just proves that one doesn't have to have a piece of paper on the wall to get **** done.
And the portable 2 post lift has been done. It's basically like 2 bumper jacks but I would expect some sort of synchronization. Put a bar across the arms and voila, gantry crane.
finn
The UP, God's country
I’m well aware of the portable lifts. They’ve been on the market for years, and are used in heavy truck shops.. I’ll bet they have sound engineering behind them, too. They’ve not the result of “try **** and see if it works”, which is what the thread is evolving to.
whateg01
Somebody should probably tell all those people who have been pulling engines with a come along and a tree that it can't be done because it wasn't designed for it.
finn
I’ve done that, too.
Definitely wasn’t safe, but I was too young and dumb to know better.
iamhomeless
Indy
Buy one of the Bendoack Super Tall 4 posts that a class B can drive under, slap the caster kit on it, modify an I beam with some rollers to ride the top rails and give it a winch.
You now have yourself a 4 post lift that doubles as a mobile bridge crane. And you did it fairly in expensively and without massive changes to the intended loading methods of either piece of equipment.
And Bridge and Jib cranes are far superior to gantrys, it's absolute night and day difference.
