Tools of Japan
HannibalLecter
Ah nice, I hope I won't go on a shopping spree now.
On another note, I got the Koken wobble fix 1/4 spinner screwdriver, to accompany the zeal 1/4 sockets and much to my surprise the fixed position doesn't work. the socket won't stay put. Big dissapointment. Has anyone else encountered this?
superautobacs
Vancouver, BC
This is why there's never been any wobble-fix extensions in the Z-series.
Z-series items work best with its own brethren.
ronkz650
Denver, CO
Koken 2763, 3763, and 4763 series are wobble fix in all 3 common sizes, but not Zeal series. They don't work well with any short sockets or hex or torx sockets even in the Zeal line.
Bad Mojo
Some new and used arrived. Had a little bit of a theme going with the Toyota stuff, but that is just fine by me. I have slowly been grabbing the different sizes Tone ratchets and now finally have 1/4-1/2. (Let this serve as sacrifice to the OCD gods) I do need to find a quick adapter for it, so it matches the others.
cbracer
Costa Mesa, CA
Did you try the larger sizes of 1/4" sockets? On my koken wobble extensions they start working once you get past 9mm if I recall. But I don't have a spinner screwdriver, only the extensions.
HannibalLecter
No, the sockets I have are 3,4,5 mm hex and t25 torx and none works
cbracer
Costa Mesa, CA
correct, the hex and torx bits in 1/4" use a base size that's between the 8mm and 9mm, hence none of them work on the wobbles. If the base of the hex and torx were the size of the 10mm socket then they would work fine on wobbles. The Nepros versions fit fine. I sent an email to Ko-ken because the detents are also placed incorrectly leaving an absolute smidgen of detent ball engagement :( Sad they didn't think through their design enough! :(
pizza
Midwest, USA
steve855
PA
I bought this ratchet from Amazon Japan back in December 2023. Koken 2726z-3/8, 72t. It's so nice, super low backdrag and a precision feel. Only problem is, now I need the 1/4 drive version and it's hard to find. Amazon.jp is out of stock and looks like they will be for quite a while.
Anyone know of another source who has them in stock, where I could take advantage of the favorable exchange rate? I don't need one, I just want one.
pizza
Midwest, USA
for a single ratchet, it might be cheaper to just go palmac with code mrsubaru5
Madjik Man
Outahere
Idaho
Bought these 8" long Tsunoda PW-SN200TG flush cutting pliers at Amazon-US for $35. Shipped from Amazon-Japan. I like the grips. The cutting edges are sharp and perfectly aligned. The pivot action is not optimal. Even after some "exercising" of the pivot joint, pivot friction is high when handles approach full open, medium when handles are closed, and low between closed and full open. I prefer plier handles that will "fall open" an inch or two under gravity. These will not. My Knipex linesman pliers and side cutters will fall open.
rick carpenter
Huntsville, East Texas
Update on my Canary ‎DC-190F Box Cutter that I got last August. I've been using it this year breaking down boxes at work for recycle and it has performed well, much better than a knife. Wrangling boxes inevitably puts my hands in contact with the blades and tip but with them not sharp I really like that I don't have to worry about cutting myself. It is about 7-1/2" long with serrated blades and a semi-sharp tip. I wipe it with a soft damp cloth and tape residue comes off easily enough.
Steel_Rain
I bought this hex key set in unused condition at a car boot sale back in the 1990s and have used it a lot since, mainly and bikes and motorbikes. They are made in Japan and of high quality.
Eight as a brand seems to be little known in the UK and USA but they are a very big manufacturer of high quality hex and Torx tools.
Their current extensive catalogue in English is here:-
I'm new to this forum, but I'm a long term tool collector. Several years ago, a fellow employee (and Porsche Technician) shared with me the Japanese "Eight" brand of hex keys he purchased while visiting Japan. Recognizing the logo from my distant past, I actually found a set of very old hex drivers (with handles) made by Eight that my Dad used years ago. These appear to be from the 70's / 80's and extremely high quality, despite being well used. I have no idea where he purchased these back then. That single impression and comparison with my much newer Snap-On set, sent me down the pathway of Japanese made tools. It's been a great journey and I've come to know and respect the "Made in Japan" stamp on things these days.
Great forum and information here.
Justin V.
Odd-job
Thanks for posting this. After I saw this I had to buy one too. My kids all have gotten banned from box cutting duty after some poor knife safety mishaps.
rick carpenter
Just discovered these!
Dickies Japan ratcheting screwdriver with 72 teeth and interchangeable blades. It's a Ball-Grip Type that can be also used as a stubby.
That seems very similar to the Vessel offering?
Dickies brand... that's crazy. When I contacted Vessel a while back, they had no interest in considering +1 or +0 bits for their 2200's.
Keegster
SC
Can the director lever on Koken ratchets be reversed?
I just used mine and found it was backwards from every other ratchet. I refuse to buy Kobalt ratchets because of this.
JWC86
No and I understand 100% how you feel. I know for some they say it doesn’t bother them but I can’t stand it and won’t live with it, I’ll just but Snap-On and Nepros instead. ***** because I really like the Kokens in every other way.
Kaffeetanne
That's what I thought too. The yellow direction switch is a dead giveaway to the Vessel 2200. However, the latter only have 36 teeth.
Unfortunately, there was no information about COO on the packaging. The only thing I could dig up was, that it was a collaboration with Factory Gear, a chain of toolstores known for doing special editions together with well known brands.
This is like i feel, too. Love the Koken for their ultra low backdrag, but can't stand the reversed switch.
