Walker Turner 1216-42 Drill press help
FordMustangKingCobra
I was recently given this drill press for free I have managed to remove most of the stuck parts except for the quill, it is completely stuck inside the head of the drill press...
20240404_130847-jpg.2087243
What I'm wondering is if this bearing guide right here at the top of the head can be removed, that way I can have better access to the top of this quill
Rick_Br
Winston Salem, NC
F
Okay I finally got the quill out after using a pipe wrench for the pair of vise grips clamped on the back and then a piece of pipe and it finally moved...
Here is the quill after it was cleaned
F
@FordMustangKingCobra Glad to see you making progress. is it fully operational now?
Not quite I'm just about to start putting it back together I figured I'm going to wait to paint it before I know it's fully functioning, and then I'll paint it further down the road, but I still need some parts for it to make it fully operational I found a few of the parts I need on eBay one of them is the original power switch and I don't know about you but $60 seems a little ridiculous for a vintage power switch, the other two pieces are like 20 bucks and then there's a bearing I need for the spindle
jjj240
CA
I am restoring for a hobby shop use, not a museum piece per se, so $60 for vintage power switch is no-go for me LOL.
I've found that the spindle bearings are no longer available in mass-market products (and the custom bearing price is ridiculous). I have decided to reuse the original bearings- soaked overnight in a grease remover and cleaned up with "light" compressed-air, then re-grease. What are you planning to do?
F
Well one of the bearings which is on the spindle closest to the check the outer bearing race was cracked, so i guess I'll have to find a replacement.
All of the other bearings I've cleaned up and they seem good I'm just going to put some grease in them and call it a day
Beerhippie
Far NE Oregon
You might be a redneck if:
20240405_185154-jpg.2088008
I mean that in the best of ways/
I used a '70s Toyota scissors jack to get the head off of my DP:
Whatever works, bro!
F
Okay so it looks like I may have found a replacement bearing that should fit the spindle and quill, it is a 1623-2rs or the other one would be a 99502h-2rs it is literally exactly the same bearing size wise by my measurements.
F
Alright, guys. I know it's been a while since I last posted an update. But I have since got the spindle to move up and down smoothly the head and table now move up and down smoothly, i have acquired the correct power switch, and an oiler cap for the top
And the motor mounting frame, now I gotta figure out what type of the frame actually fits this drill press because a number 48 frame is too small..
