BroncoAZ
How about a 100 MHZ oscilloscope w/ 7" screen for ~$60 after applying 40% off coupon. Looks exactly like a rebranded OWON SDS1102 or Hantech equivalent.
You just gave me PTSD flashbacks of my dad’s 1970’s oscilloscope that he used when building the Heath Kit TV we had for most of my childhood 😂. That thing was large and heavy, unfortunately I just moved it a gazillion times without ever learning how to use it. That new one is only a couple inches deep and probably weighs 1/10 of the old blue box.
ching0n
Flexzilla Air Hose, 3/8 in. x 25 ft., 1/4 in. MNPT Fittings, Heavy Duty, Lightweight, Hybrid, ZillaGreen - HFZ3825YW2 https://www.amazon.com/dp/B0021WVO8W?tag=atomicindus08-20
This is now down to 12.98.
50 foot hose is about double the price at 24.98. $10 cheaper than normal.
Flexzilla Air Hose, 3/8 in. x 50 ft., 1/4 in. MNPT Fittings, Heavy Duty, Lightweight, Hybrid, ZillaGreen - HFZ3850YW2 https://www.amazon.com/dp/B001C6NC7O?tag=atomicindus08-20
looks like 25' deal is over. Picked up the 1/4 50' at decent price though. I need to make some welding hoses.
Tinkerer2
Central Florida
Still waiting for the flexilla 4200 psi pressure washer hose to go on sale. Is there a way to get notified when an item does have a special deal or do you just have to keep checking Amazon?
V
vwpieces
Hills, PA
Ad it to your cart, then save for later. Keep checking the price. Wait, wait, wait... Price is more likely to go up than down, so don't get your hopes up. Likely to go lower in fall with less demand.
Dollar funnel deal still going...
srs2000
Keepa.com is what you want
Fatboy148!
There is also https://camelcamelcamel.com/
The problem I have had is the time delay between when the price drops and when I get their message re: the drop.
Amazon will give you notes like this when the price of things in your cart changes:
Important messages about items in your Cart:​
2 items in your Saved Items have changed price.
Items in your Shopping Cart will always reflect the most recent price displayed on their product detail pages.
I bought this particular jacket from sx to xl for grandkids. Most were in the $24.00 range when I jumped. Sometimes the price goes up, sometimes it drops. Look at the historical data and make a decision as to what you want to do, buy now, or wait. Sometimes, you can get the bear, on the other hand, I hate it when I get got by the bear!
$18.80 to $76.00
Got to love those algorithms!
Fatboy148!
Fatboy148!
OOOPS, I put this in the Amazon section.....
I ordered a bunch of Fiskars stuff from them last week and it arrived fine. If you order $50.00 shipping is free. Less than $50 and shipping is $7.99. I ordered one of the Kangaroo Garden bags and my bride liked it. I went back tonight to get another, and it was $10.00 instead of $15.00. From my experience, Fiskars is pretty good at honoring their Lifetime Satisfaction Warranty.
https://www.als.com/fiskars?map=ft
MOS3522
Colorado
I get a lot of use from this style funnel on my cross-country drives. It really saves time. ;)
ching0n
You can get that for $60? Last time that I used a scope was the late 90s, and thatTektronix scope was in the low 5 figures back then, but this is so cool, it's hard to resist, even if I don't really need it.
this is a different make but I suspect it's merely a rebrand. I don't need a scope, I don't know how to use one really, but it's a hard deal to pass up; we'll see if anything majorly wrong when it arrives based on those two videos.
I kind of wish it had a signal generator and maybe CAN bus sniffing though.
srs2000
alright this should be the last car sound deadener I post because I'm done with one car and the 2 I ordered will finish the second.
VEVOR Car Sound Deadening Mat, 80 mil 10 sqft Car Sound Dampening Material, Butyl Automotive Sound Deadener, Noise Insulation and Vibration Dampening Material for Car https://www.amazon.com/dp/B0CPY53P69?tag=atomicindus08-20
$9.90 with a 20 percent off coupon. About $8 after coupon for 10 square feet of 80mil. No foam like the other ones had but It will go in places the other couldn't. Most likely the cheapest you can buy online right now. This was about $30 and then $17.
2manytools
Mt Pleasant, MI
They had the 25sq ft down to $15.99 a few weeks back. I think that's the best price I've seen
srs2000
I wish it stayed that low. It's $39 now. I got 2 boxes at $16 and then ordered a 3rd at around $25. My guess is Vevor dropped the price temporarily to boost their sales/visibility in searches to game the system.
So far I love this stuff. Everything sounds more solid and it's not a lot of weight if you don't go crazy with it.
srs2000
You might want to search vevor and sort price from low to high. They're clearing stuff out and there are some deep discounts. $6 space heater, $8 100 foot pressure washer drain clearer, $10 bar cart, plastic welding kit, $10 diamond drill bits, Tesla charger adapter thing that I wouldn't trust, .... There's just a lot of stuff that may or may not be ****.
VEVOR Pressure Washer Hose, 100FT, 1/4" Kink Free Brass Thread Replacement For Most Brand Pressure Washers, 3/4'' Bending Radius, 4200 PSI Heavy Duty Power Washer Extension Spray Nozzle https://www.amazon.com/dp/B0CF59DFSX?tag=atomicindus08-20
VEVOR 6PCS Diamond Drill Bits 3/4",1-1/8",1-1/4",1-1/2",1-3",2" Tile Diamond Hole Saw Kit Vacuum Brazed Diamond Drill Bit 0.59in Segment Tile Hole Saw w Storage Case for Tile Ceramic Porcelain Marble https://www.amazon.com/dp/B09CKH62MZ?tag=atomicindus08-20
VEVOR 6 x 18 inch Drop-in Fire Pit Pan, Rectangular Stainless Steel Fire Pit Burner, Natural & Propane Gas Fire Pan H-Burner 90,000 BTU for Indoor or Outdoor Use https://www.amazon.com/dp/B0CGX3QPCS?tag=atomicindus08-20
VEVOR Electric Space Heater with Thermostat Remote Control, 2-Level Adjustable Quiet Ceramic Heater Fan, 16in Tip-Over Overheat Protection Small Heaters Built-in Filter for Office Room Desk Indoor Use https://www.amazon.com/dp/B0CQN97WKM?tag=atomicindus08-20
VEVOR 24 inch Round Drop-in Fire Pit Pan, Stainless Steel Fire Pit Burner, Natural & Propane Gas Fire Pan 92,000 BTU, for Indoor or Outdoor Use https://www.amazon.com/dp/B0CGX3HVKG?tag=atomicindus08-20
VEVOR Fire Pit Grate, Heavy Duty Iron Round Firewood Grate, Round Wood Fire Pit Grate 19", Firepit Grate with Black Paint, Fire Grate with 4 Removable Round Legs for Burning Fireplace and Firepits https://www.amazon.com/dp/B09BC1264T?tag=atomicindus08-20
VEVOR Plastic Welding Kit, 100W Plastic Welder Soldering Iron Gun, Car Bumper Repair Kit with 2 Welding Tips, 1 Soldering Tip, 20 Plastic Welding Rods for Kayak/Toys/Plastic Tested to UL Standards https://www.amazon.com/dp/B0CJBMVF4X?tag=atomicindus08-20
ching0n
Amazon search just like google search now a days is not made to give you the most relevant results but rather extract the most amount of money from you. When you sort by price (low to high) you'll see that many results disappear (say from 900+ to 50). What I do instead is use the price slider filter on the left to set a low price range and then browse manually. You have to be careful that Amazon doesn't then apply the category filter (say tools instead of all).
