Have an old 26 gal (I think) that I have had for about 25 years. It as an oil free compressor motor. It is still running strong except for a small hose issue.
The pipe/hose that goes from the compressor exhaust into the tank will not stay in place. I can't remember if I have replaced a factory flex hose at some point, or if it was always a piece of 1/2" copper tubing.
The connections to the head and the tank are Similar to union type fittings, but they have small rubber gaskets that are similar in size to what the union ferrule pieces would look like.
When I tighten the nut all the way down, there is still no solid seal with the rubber gasket piece and the pipe piece is forced out by air pressure.
How can I fix this? Can a regular union nut be used or do I need to buy a specific high pressure hose of some sort?
