CGarage
Which vessel one?
I'll have to check it out. Of course 90% I'm hitting it with a hex impact anyhow but you know.
Which vessel one?
I agree but I bought mine in 1988 and it's high leverage and durable. Put so.e vessel bits in it!The SO ratchet screwdriver is old tech.
The Vessel Japan ratchet screwdriver I think is far and away better.
Agree with all above and below this sentence. Sometimes the folks testing wrenches don’t always consider everything they should.Wright wrenches outperform (SnapOn) and every wrench I'm aware of.
The new SO soft grip ratcheting screwdriver’s end cap is a miss in my opinion. Comes off at inopportune moments. I feel that’s a design flaw.I prefer the Vessel mechanism as well. I find it more refined. I prefer the shaft dimensions on the SO/Williams, however.
The new SO soft grip ratcheting screwdriver’s end cap is a miss in my opinion. Comes off an inopportune moments. I feel that’s a design flaw. And some have plastic washers where the replaceable shaft enters the handle that drag on the shaft making more back drag than they should have and really limiting their utility. I’ve fixed some of mine by carefully reaming up that washer.
Thanks for linking it.
So happens im from Barberton, OH. My grandfather used Wright and did some machining work for their production equipment.Agree with all above and below this sentence. Sometimes the folks testing wrenches don’t always consider everything they should.
Snap On wrenches are very thin, which is generally good. They fit more places. Even a marginally thicker wrench has strength advantages. I recall a test against Stahlwile. The Stahlwile wrenches were much bigger. If you have the space, the bigger wrenches may be superior.
Generally, Snap On engineers the smallest possible tools and uses superior materials and processing. Resulting testing may show them comparable, but if you compared size, I think a bigger difference would emerge. (Stress=force/area, more meat generally means lower stress)
I will say, when I first used SnapOn wrenches, I found their beams too thin (compared to craftsman raised panels for example). I got used to them and now prefer them. Especially appreciate the long pattern, which are very long.
Not saying wright aren’t better wrenches or that I wouldn’t love them. Only that I no longer trust YouTube reviewers. 100% agree with, “you can’t really go wrong with Snap On”. May not be best, certainly highest cost option, but no real bad snap on tools, which makes this thread hard to answer.
I just have an aversion to any screwdrivers that take the short bits.
SK ( even the new Chinese ones) flare nut wrenches equal snappy, though this is a very hit or miss category that you can't just choose any big name and they're awesome.
Recent attention aside, I'm a fanboy. lol
Interchangeable drivers bug me unless they use the 4" bits or whatever, where the bit makes the vast majority of the shaft.What?
I could see that.... IME if I have trouble with my SK...my buddies snappys havent helped , but I could still see them being considered a snappy "must have".Not in real life. I went at a total brake system replacement (only the booster didn't get replaced) on a rusty, thirtysomething Volvo 245 w/ dual circuit brakes. I had both my Snap-On and USA SK flare wrenches. Snap-On was a step above. Without a doubt.
Wright does make really nice wrenches, though the Wright-Grip is not kind to fasteners. I do like the thicker handles. I seem to grab the Wright wrenches for under-car stuff, and the Snap-On for engine stuff.
-Ryan
Do they have a stubby version? That is really why I went Snap-On because at the time I bought it I was unaware of anyone else having a stubby. Then I had to buy the full size one because the Craftsman knockoff version's ratchet mechanism worked backwards from Snap-On and switching between stubby and regular just wasn't working for me. I know what you're going to say but the lower backdrag of the Snap-On makes it much more pleasant to use than the Craftsman as well.
Unfortunately I handed my landlady the Snap-On SSDMR4 and haven't seen it in two weeks :/ (she's actually super nice I just keep forgetting to ask for it back)
Tbf though when I was up north , you just didn't bother, just cut it and put a 6pt socket on it because you'll never not twist the lines off at that point anyhow.
Now that I'm down south, hell its rare I couldn't just use a regular open end. Exception being marine stuff but basically any line wrench tends to work on those stainless.
I guess I haven't done a huge amount of struggling with lines.
Now that I'm down south, hell its rare I couldn't just use a regular open end. Exception being marine stuff but basically any line wrench tends to work on those stainless. If you were in any danger of rounding it you already had bigger problems because most likely when it came out the aluminum it was screwed into was coming with it.
Maybe at home, or down south where I'm at I'll do that , but back north burning up time trying a 50/50 shot to save a rusty $7 line that I can make new in the same time with the bonus of switching it to copper nickel never made sense in the shop.You gotta hit the tube nut a few times with a torch and water quench it. If you don't melt through the line because it's so thin it can't handle the heat, they'll normally come apart. If you can get it wiggling sometimes you can spin the hose off and spin the new one on to the stuck fitting.
IMO the SKs I have a inferior to my snap ons. Plus side is the SKs normally just spread and slip, where the snap on will normally blow off the corners.
Cheaper and better end result for the customer was typically just cut and go.
Yes they do I will look for it and post link.
Waiting on them to release the smaller ones in Power Blue to match the LN47ACF I have.+1, but in both sizes.
Pretty sure it’s the same number but 46 rather than 47Waiting on them to release the smaller ones in Power Blue to match the LN47ACF I have.
What’s the part number for the smaller ones, anyhow?
So...this made think....."the unthinkable"... Mine are offset, and not US.I've had luck with the torch-n-quench before. I always worried about the integrity of the rubber line. Now I just kill all traces of the rubber line's fittings with fire.
My SK's are short, and have no offset. The Snap-Ons are longer, with a mild offset and work a treat.
-Ryan
Sorry for the late reply. LN46ACF is the number, mine are with red grips.Waiting on them to release the smaller ones in Power Blue to match the LN47ACF I have.
One of my wife's girlfriends said the same thing to us. She had and ebay business, and the fees and all have just eaten into her profits. She ended up closing her store I think.That is because eBay has shot up so much on charges to the seller. I sold a socket set for $275 plus $9 shipping. The buyer paid $305 with California sales tax. eBay charged me 13% on the whole nut, so got 13% of the shipping and the tax. Their payment to me was $244, and I still had to pay $19 shipping. So a$275 item netted me $225. The deals on eBay are evaporating because eBay takes so much of the money that, unless you just want to work for them, it isn’t worth the effort. I am trying to eliminate a 45 year hoard. So far, between the post office, eBay, and my own ignorance, it has cost me more than I have gotten.
I have a buddy that sells on Amazon and eBay but also has his own website. He maintains the presence on those because that's were shoppers go first vs some random website but he includes the details with the products when he ships them and offers discounts if they buy straight from his site.One of my wife's girlfriends said the same thing to us. She had and ebay business, and the fees and all have just eaten into her profits. She ended up closing her store I think.
I, too, have a hoard of stuff to get rid of and thought about doing ebay but that has evaporated.
To the OP's question: I agree with the idea of getting Snappy tools that no one else makes or offer a function no other brand can match. I've been rebuilding ratchets for years, and didn't realize what I was missing till I got the S-O ratchet spring tool. Man that little thing is great! SP744 I think.
Yep. The slip joints especially are so goodpliers- regular slip joint and the needle nose
Tekton ratchets are better than Snap On?Tekton ratchets are similar in all regards but stronger.
I'd say so. It could sway a little one direction or the other depending on the exact model but I would say more tektons come out ahead overall. I wouldn't argue with calling them even really. So considering their 1/3rd the price I can't call the snap ons a must have.Tekton ratchets are better than Snap On?
I would probably clean them before declaring another brand better.I'd say so. It could sway a little one direction or the other depending on the exact model but I would say more tektons come out ahead overall. I wouldn't argue with calling them even really. So considering their 1/3rd the price I can't call the snap ons a must have.
Right now I have husky, Cornwell,snap on,kobalt,tektons, icon. Some of my snap ons sit there unused but just because they feel clunky and probably need cleaned. The Kobalt 1/2" don't get grabbed a lot just because they feel like a heavy oversized brick. Otherwise they'll all get used without a sway in any direction so I can't say " oooh , gotta have my snap on ratchets".
Clearly not the reason. Point is I haven't bothered because I don't miss using them by comparison. Even with the newer ones that don't need it, they give me zero reason to reach for them over the tektons. I wouldn't miss them if they got tucked away somewhere.I would probably clean them before declaring another brand better.
Which particular tekton model ratchets do you like so much? I dont hear much discussion on them.Clearly not the reason. Point is I haven't bothered because I don't miss using them by comparison. Even with the newer ones that don't need it, they give me zero reason to reach for them over the tektons. I wouldn't miss them if they got tucked away somewhere.
I have their 3/8 flex head, 1/2 drive non quick release release and 1/4 flex stubby. In practice I just don't feel any difference outside of the 1/4 stubby has pretty low back drag. In what tests I've seen with strength etc. they come out even or better than the snappys.Which particular tekton model ratchets do you like so much? I dont hear much discussion on them.
Well that's entirely different.I have their 3/8 flex head, 1/2 drive non quick release release and 1/4 flex stubby. In practice I just don't feel any difference outside of the 1/4 stubby has pretty low back drag. In what tests I've seen with strength etc. they come out even or better than the snappys.
Again it's not so much liking them so much ( besides price) it's more like i could take either and I'm not going to complain.
Same. An ancient snappy that feels sloppy and is just worn, a probably dirty snappy that feels notchy with lots of back drag, both kobalt 1/2", all the craftsman ( dont know why i keep those). That's all I can think of ATM. In practice the differences are so marginal amongst anything decent I just can't call too many ratchets a must have.Well that's entirely different.
I only have a couple ratchets I actively try to avoid using.
