ching0n
I have had one of those for years. ... It's OK, a bit under powered, nothing to get really excited about. Mostly replaced it with an Evolution Cold Saw.
I find that the abrasive disc wandered too much for decent miter on the ones I used. I might go the cheapo cold cut route; all metal makita miters are a dime a dozen on marketplace:
or this plus a track:
or this one:
dogdog
or this one:
LOL does he have a cold cut saw or a dry cut saw ?
But weird, I was just at HF 30 minutes ago looking that that 5-3/8 metal cutting blade.
ching0n
Been needing a tacho for a while; might pull the trigger on this one. There's several in this price range but seems like the 9V battery models drain them:
tabs
wv
don't think i saw these posted yet...
VEVOR Tool Belt, 13 Pockets, Adjusts from 29 Inches to 54 Inches, $4.99​
there are one or two more around this price range too.
VEVOR Plastic Stackable Storage Bins 24 Pack (5 x 4 x 3-Inch), Hanging Stackable Storage Organizer Bins $24.74​
i feel like this is a really good deal compared to how much those akro mills ones cost
VEVOR 50PCS Oscillating Saw Blades, Universal Quick Release $19.02 (- 20% coupon off)​
Sumboodie
AK
Strange, still $60 for me, though now has a 30% coupon.
Id post the screenshot but thus forum doesn't load them for some reason.
Was thinking it'd be worth trying out as an air feed for a brush burning setup.
logixjock
Sturgeon, MO
I just bought one for an air feed for my new compost setup.
Sumboodie
AK
I tried my parent's address and it gives that price. But then it's $80 shipping. 😬 so much for Prime free shipping eh?
Guess what it shows up for me is the "deal"
srs2000
Anyone have any duds so far from Vevor? I'm still waiting on some sound deadener without foam that "shipped" a week ago but in reality they just made a label. The other stuff I've been good with. The heater is a steal and is still available. Gets hot fast, has a remote, and can rotate back and forth. The previous sound deadener - so far so good but I guess I will find out when its July or August as I put it behind the headliner on the roof of a black car. Sure hope it doesn't melt off.
This was when I was about 90% done with a door. Neighbors probably think I'm insane because I keep knocking on panels with a satisfied look shaking my head yes.
ching0n
There's dozens of these things at this price point and ordinarily would shy away from wire ones because they sag w/heavy power tools but I think are ok for 12v drivers. I find myself wanting certain tools quickly accessible by the garage door and this one fits the bill I think plus it's modular. Pro-tip, if you want to avoid sag, look for one w/a sturdy upper shelf from which you can wire the bottom supports:
also came across this one that may work for people's toolboxes:
Just put together the tool rack and it's not a bad deal, Plenty stout (thicker gauge than my last one I want to say), decent finish, and they even threw in spare hardware of all fasteners (I think the masonry fasteners is probably 5$ alone at your HW store). I'm not sure the hammer rack will work w/my handles but the hook side can also accommodate. The drill 'index' isn't labeled and I might swap shelves since I went by the instruction manual which doesn't let me have a small circ saw on top.
Cable straps also came in and I might order some more since I ran out. Carabiners are plastic but will serve the job for my needs.
V
vwpieces
Hills, PA
It's been this price pretty consistently for the last 6 months or so.
I posted it back in Dec 2, 2022 and it was the same price. Price does vary on amazon depending which department you happen to be searching for the Same also sold by Amazon. I needed more and seeing it hasn't gone up since is pretty amazing.
Also when members use the link it benefits the site.
ching0n
What is the relevance of this comment?
I didn't even know that was a thing (unless actual sponsor). Looks like Wal-e world carries it at same price. Good deal having it delivered to your door though .
srs2000
All of the Amazon links posted here get stripped of referral codes and then get a referral code inserted by garagejournal.com. The site gets a commission on every sale. It's a good idea really.
XXL__
@XXL__
Ryan/the site gets a referral fee which is how the site is supported and why it is free.
Welcome to GJ.
The question was, "what is the relevance of this comment?" The context was "as a response to my posting that hand cleaner was regular price." And it was directed to @vwpieces, who made the comment. I am well aware of referral mechanisms. I have been a fan and supporter of Ryan's undertakings for nearly 20 years (I spend most of my time on the HAMB). The only remotely on-point response to my question came from... wait for it... the person I asked... @vwpieces. I want Ryan to get everything he's due and then some, but posting regular priced items in the "Hot Deals" forum because Atomic Industry gets a $0.27 cut seems a bit skewed from the forums intent, dontcha think? <-- intended to be rhetorical, but putting on my flame suit nonetheless.
V
vwpieces
Hills, PA
I think a gallon shipped to my door for $10.97 is a Deal. Likely the best deal out there. If not, show me otherwise.
srs2000
Madjik Man
srs2000
Received two sets of these. The bits are great.
The holder is baffling, to say the least. Will just end up putting them in a small container in my box.
Looks like it's got a built-in magnetizer. If it actually works well it might be pretty useful. Might be large for small bits but probably is more practical on the long blades like here -
VESSEL Ball Grip Screwdriver (for home use/Black) [No.220W-BC3C] (interchangeable) (Japan Import) https://www.amazon.com/dp/B01N4G7AA8?tag=atomicindus08-20
While not an amazing price this is the lowest I've seen this:
VESSEL IMPACT BALL™ Torsion Bit 30+1 PC. Set in SLIDE CASE No.IB31P02U Made in Japan by VESSEL https://www.amazon.com/dp/B08WHYFQYL?tag=atomicindus08-20
$26.81 - normally about $31.
