srs2000
I don't think anyone has posted this.
VEVOR Air Compressor Filter Regulator, 1/2" NPT 5μm Air Dryer for Compressor, Single Stage Semi-Auto Air Compressor Water Separator with Brass Filter Element, 7.5-125PSI Pressure Regulator, Poly Bowl https://www.amazon.com/dp/B0CC8HQ3FZ?tag=atomicindus08-20
$10
One box of the sound deadener without foam arrived earlier in the week. The other I might have to contact them about. No FedEx scan data. What I got seems to work fine. The one with the foam is way easier to handle / install but it's too thick for certain spots. Might try adding some to the washer/dryer/sink if I have extra.
Heated blankets. Really soft and work. About all I can say right now. It's nearly 100f outside. I'd expect to pay several times more locally at Walmart or target. I paid 2x more just for a heating pad actually.
Jacobs976
Indiana
More volume than the previous one I posted;
Just got mine in. Looks fine but haven't tested it yet.
It comes with two baskets, one full size matching tub and one little ~2"x2" square, and a cord. This model does plug in while the smaller unit I believe takes two AA batteries. I think the corded version is ideal.
Also came with a few mystery hairs of the short, black, and curly variety stuck to the exterior of the case.
Was packed well, foam top and bottom padding and properly fitted box, but it did ship FedEx so I had a 4 day delay once it hit the local hub(out for delivery each day but they're using a contractor delivery service for my area which is spotty). Met the driver in my driveway in an unmarked white delivery truck like a UPS truck and he pulled the box off the top shelf, climbed up on some bigger boxes to reach it because the truck was overloaded.
Also whoever ordered HVAC filters, they didn't take 150 lbs standing on them well.
Overall looks good for the price assuming it works fine. Would recommend cleaning before use though, just a quick wipe down really. Big issue is make sure you're in an area with decent FedEx service.
ching0n
I ended up getting both since the small one is ideal for eye glass duty and the bigger one for nuts and bolts and such (I use mineral spirits). The small one takes a USB size wall wart w/a barrel adapter. Bummer about them hairs.
Jacobs976
Indiana
The big one uses a traditional 2 prong to standard outlet plug(just stating for others looking at them). When I was looking at them before I thought I had seen the smaller unit using 2 AA but I guess that was a different model/brand with the same tank size.
I'll be using mine for watch parts, clock parts, and misc parts/tools so I wanted to make sure I'd have enough room to actually fit most parts.
dogdog
All my eight boxes came in crushed but still fine…. they are pretty well packed. You might have a gorilla there working your route. Also she might be lying about her weight. Might be a 300lb gorilla.
Jacobs976
Indiana
The side of the box caved in a bit, probably bent the corner of the filters, but they probably aren't damaged that bad. It wasn't my package(just seen the print on the side of the box with the picture of a filter) so I'll never know but I'm sure whoever got it probably wasn't happy regardless.
The guy had to climb up on top of that box and the others to reach my package that was tucked in the top shelf against the wall with more packages filling in the space in front of it.
Basically just a contract delivery guy running a route that was probably 4 days behind with the van loaded up with everything that was supposed to be delivered those days. Looked like they had a professional Tetris player pack the van.
mikeinri
Out here, FedEx was much more reliable before Amazon blew up. That started a race to the bottom for FedEx, and shipments switch between FedEx vehicles, the fly-by-night random vehicles, and worst of all, the hand-offs to USPS, which always adds at least another day.
Fortunately, most Amazon stuff now comes in an Amazon truck. But, FedEx from anywhere else is a complete crapshoot.
Mike
(Edited for clarity.)
ching0n
It says abs not stainless steel.
looks like the different options offered are priced the same. I want to think there's some loss in translation there but haven't gone through the reviews. I'm thinking they're talking about the covering of the rinse pipes:
Etchase
Hawaii
I purchased the Vevor caulking gun and it was DOA. I purchased a Vevor numbered drill index storage box and it was top notch. Same with a shell fish cracker and meat grinder. 1 in 4 isn’t bad, but bad enough that I will continue to buy thru Amazon for the easy return option.
ching0n
Did you use the vevor battery or makita? (I think that's what reviewers said also worked). Bummer, I was eyeing that one.
srs2000
ching0n
VEVOR Chainsaw Planking Milling 14" to 36" Guide Bar Wood Lumber Cutting Portable Sawmill Aluminum Steel, Sliver https://www.amazon.com/dp/B073WW2F3J?tag=atomicindus08-20
$20 was about $80
VEVOR 10 x 15 ft Pond Liner, 45 Mil Thickness, Pliable EPDM Material, Easy Cutting Underlayment for Fish or Koi, Features, Waterfall Base, Fountains, Water Gardens, Black https://www.amazon.com/dp/B0BZYGB3HY?tag=atomicindus08-20
$17 after coupon. Was $150.
that saw thing is neat. A couple of neighbors had trees fall recently and I've been looking for an excuse to grab a few stumps and make an anvil stand but wasn't a fan of not having a non-square shape
BobsYourUncle69
Westchester New York
Gedore 1/2 coupler , cheapest Ive seen them so far,
$7, it can't hurt to have a spare as these fail long before the mechanism does, so simply get a new coupler and the ratchet lives on.
Might be a bit short for other ratchets but got one specifically as a spare for my 2 Gedore 1994 ratchets.
GEDORE 1994 Coupler 1/2" https://www.amazon.com/dp/B000UZ33ZO?tag=atomicindus08-20
skamath
There seems to be an additional $6 coupon on it bringing it down to about $14. Not sure if everyone can see the coupon.
tabs
wv
more VEVOR stuff. i don't think any have been posted yet but if so...oops.
VEVOR Power Tool Organizer, 4 Slot, 2 Layers, 2 Pack Cordless Drill Holder Wall Mount, Battery Charging Station Storage Rack, Multi-Function Garage Organization, Heavy Duty Metal Shelf for Screwdriver $12.99​
VEVOR Bolt Cutter, 18" Lock Cutter, Bi-Material Handle with Soft Rubber Grip, Chrome Molybdenum Alloy Steel Blade, Heavy Duty Bolt Cutter for Rods, Bolts, Wires, Cables, Rivets, and Chains $12.59​
VEVOR Metal Cutter Drill Attachment, with 360 Degree Pivoting Head, Metal Shears Attachment, Cut Max. 21 GA Stainless Steel 14 GA Aluminum Metal Sheets and 18 GA Galvanized Steel $9.99​
VEVOR Chainsaw Sharpener, Hand-Cranked Chainsaw Sharpening Jig Kit for 4"-22" Chain Saw, Potable Chainsaw Chain Sharpener Tool with 4 Sharpening Heads, Storage Bag for Home DIY, Lumberjack, Landscaper $9.99 -20%​
VEVOR Auger Drill Bit for Planting, 1.6 x 16.5 inch Garden Auger Drill Bit, Spiral Drill Bit for Bulbs Planting & Holes Digging, 3/8" Hex Drive Drill $6.99​
