Need some ideas for small fixture table for welding.
motorcitykid
Detroit River
This is my bench it’s 3’x7’ 1/4” steel, I am learning to weld and want a small fixture table I can set on it and bolt down to weld on.
I have this little 1/2” thick chuck of cast iron but would like for it to be 24”x24” with a little vertical section.
I was trying it out today trying to see what would feel right. I’d love to have a Primeweld table but I’m just learning and it’s not for business so I can’t see investing that kind of money in something that I might only do once in a while.
The idea is to be able to make some fixtures and jigs to help me keep things square and for repetition.
What are your thoughts?
cvairwerks
Within hearing distance of Texas Motor Speedway
Maybe start with a fixture plate from Fireball Tools....
motorcitykid
Detroit River
I was looking at these last night, I love his dragon wagon but I’ve got to be able to put it away. This one you shared is more in my wheelhouse. Thanks
motorcitykid
Detroit River
Stop by and I will give you this base from a heavy duty drill press. It has the T slots for fixturing. It is cracked where the column attaches. I didn't trust welding it so I made a new base.
I appreciate that, I absolutely love my drill press like the one this came from. I’ve got some hold downs from other machines mounted on it right now and it’s a beast. If I was closer I’d take you up on that.
cruzer75
This YouTube guy VinyB 57 designed a fireball type table using laser cut plates. He has plans for a bunch of sizes available. Check it out.
motorcitykid
Detroit River
The table saws tops are pretty thin, I’ve got a steel supplier nearby I’m going to see what’s available in a smaller size 24x24” is what I think would be ideal.
