Washer leaking (during drain cycle) at drain hose
reznunt
Socal
I just moved into a 55 year-old house. The washer drain pipe is 2" in diameter and there is a roof vent stack right next to the washer drain pipe. The drain pipe opening for the drain hose is located at exactly the same height as the washer.
After about 10 loads of laundry, my HE washing machine began leaking (only during the drain cycles) at the connection of the washer drain hose and drain pipe. It would just back up and begin spitting out right at the connection. I already used Draino and a 15ft snake to rule out clogged pipes. Also, when water is just poured into the drain pipe it drains just fine.
People in the online forums with the same problem say I could have an air pocket in a high section of drain pipe that's causing the backup (which would require an additional vent). I hope this isn't the case. Anyone know what else it could be?
As for solutions, many people online have been saying that simply duct-taping the drain hose/drain pipe connection (creating a pressurized line) will solve the problem with little work. I know it's just a band aid fix but it worked on my last laundry load I did. If anything it buys me some time.
Please help! Thanks in advance! :)
Northstar9126
Northwest corner Wisconsin
It may be that there is a partial blockage of the drain futher than 15 feet down the line. You probably are not getting enough water into the line as fast as the washer is when it is draining to cause a back up when you poured the water in to the drain. I would figure out how far it is to where the washer drain ties into a main drain line then make sure that I ran a snake at least that long down the line. Worth a shot.
rodnok1
NC
Had the same problem at my last house, problem is that line probably necks down and or it doesn't have enough angle in it. Newer machine push alot more water quicker than the old ones. I fixed mine by putting a rubber connector on the hose and pipe thats secured by clamps. Never leaked again.
hydramatic
Alabama
rod out that line..rent one..new machines pump 17 gal per min..I just cleaned mine last month....I used all 50 ft of the rodder while hot water was running in the sink...fixed...
BillK
Beautiful Southern Maryland
I had to go about forty feet to get mine cleared out :( It drained fine if you just did one load, but after a few it started backing up :( I ended up calling a friend who does septic work and he came out with a power auger and went clear to the street. Said he hit a backup at about 40 ft.
R
reznunt
Socal
i know the flow rate of the washer draining is greater than what i can pour down the drain, but since it backs up right away during the first drain cycle, i figured the if there was a clog it would be pretty close to the stand pipe. but thanks for the info... i'll crawl under the house and try to see how long the drain line runs. i'll definitely try and get a longer snake in there.
R
reznunt
Socal
that sounds like a fancier fix than duct tape. i'm gonna look into that for the short term. thanks!
mackrmnn
Midlothian, VA
My mother's washer did this when we replaced it with a new model. The old washer had no issues but the new one drained much faster. This product fixed the problem... Drano was no help.
imagerequest.aspx
R
reznunt
Socal
that sounds like what comes outta me after eating at the taco truck. i'll have to try that. thanks!
