Bendpak 2 post 10k lift anchor concern
KSJeff
Andover, Kansas
It's a BP9 and it's rated for 9K. My buddies truck has been on it a few times for body mount changes and some suspension work. It's a 2007 Ford F350 and it's curb weight is listed at 7100lbs. My Tahoe is almost 6K and it's spent a fair amount of time up there too.
C
CPete13
That is great information, I appreciate you taking the time to reply!
PotvinV8
California
I have a similar setup as KSJeff and have had it installed in two different locations. One on the original slab poured back in the '40s and then moved it onto a new 4" slab (extended the size of the garage). Lots of cars up in the air over the years, some for lengthy amounts of time without a problem. I went through the initial second guessing regarding safety, slab thickness, fasteners, etc.
Not sure I saw it mentioned, but when I purchased my lift, I also purchased four 2-ton Tripod Stands and I'll place one at each corner of a vehicle that might increase the pucker factor like a longbed truck or station wagon. They really help stabilize things and increase my piece of mind. Just don't forget to move them when you lower the lift! :D
C
CPete13
Thank you, yes that definitely helps ease my mind a bit and is great information to know. Yes I definitely plan to buy at least 2 screw jacks for the larger vehicles. Thank you for posting on here though, I really appreciate it!
N_Jay
The stands are a great idea. I bought 2 figuring that don't need to hold much to stabilize the vehicle.
