LeeG
Phoenix, AZ
My neighbor wanted a steel table frame that would fit over his printer stand. Drew it up in Fusion 360, verified dimensions, and cut and welded it all in a few hours. I didn't get a photo of the finished project, but here's the design. He'll add a butcher block top to it.
Pretty basic build, 1x1 16g, 1x2 14g, and 1x3 16ga tubing with some threaded stem casters. 50" x 20" x 41"
Lee
DAVE94LIGHTNING
Designed and built a few of these T handle racks. Made them for my moto service tool box because I didn't like the available options. If anyone wants the .dxf cut files to make your own let me know. Or if you want the pre cut pieces to weld one yourself I can do that too.
Brent T
Arizona, USA
Finished cleaning / polishing all the chrome bits for the CBX. Next up is all the painted parts. Just need to clean and touch up a few scuffs here and there. Fuel tank is packed up ready to get a liner since it's rusty inside, then need to clean and touch up the fairing, side panels and saddlebags (which I recently learned are called "panniers" if you want to sound sophisticated :D ). After that, I'll drop the engine, pull the carbs and start cleaning all the aluminum pieces. I'll get the carbs rebuilt and start putting it all back together. Today a big box of miscellaneous small parts showed up from the UK and other parts are on order from Germany. It's getting tough to find OEM pieces for these old bikes.
DAVE94LIGHTNING
What equipment did you use to get those pipes so nicely polished especially in the difficult to reach areas?
nadogail
Coronado, CA
Glued and nailed enough legs together for three more Elevated Raised Bed Planter Boxes.
I find that building the boxes in batches from interchangeable parts speeds things up.
I will have more room in my Workshop after the repair technician brings and installs the heating element for the electric dryer that will be moved into a rental. The washer and dryer are taking up a 4 X 8 space in my Workshop that is in a Two Car Garage.
Roger M
Snohomish, WA
Built a rack for artwork.
My daughter's birthday is this week, and she mentioned awhile back that she wanted to buy a rack to store her paintings. I thought I could make something for relatively cheap that would suit her needs.
Anyhow, a learning process for me being a novice woodworker. I found out the hard way that a spade bit is not ideal for this project(especially for drilling 1x2 oak). Ended up bending a good 3/4" spade bit in short time, and ruining some wood.
Bought a cheap set of forstner bits and all is well again. In the end, I probably could have picked up something from Amazon for the same money as I invested. I'm confident that this is a better quality piece though. I still have some sanding to do(glue residual).
rburke65
Canfield, Ohio
Bought this ‘80-‘83 Lincoln Continental front end years ago at a swap meet…$75. Going to be a wall hanger, so I started on it about 10 days ago. Taking it apart…removing hoses, wiring and cutting away pieces in an attempt to make it lighter. 95% of it was fiberglass ….who knew? Clean up the chrome, wash it….primer n spray bomb. Still have to wire in some LEDs and figure how to hang/mount it. Getting there
kaymccampbell
Upstate New York
Gonna make the doors open?
kaymccampbell
Upstate New York
Have the same thread checker, I think. Very handy.
I like it because it can be brought to the item to test, and shoved into tight spaces to test, unlike the ones on a card. I hesitated buying it a couple years ago. Glad it showed up today. It was more than handy checking new machine screws for tapping the box on the garden shed receptacle project.
dwasifar
that looks neat ! do you have plans available ?
Not as such. All you need to do is cut 27 identical blocks and glue them together in these shapes:
Those seven puzzle pieces fit together to form the large cube, and any number of other interesting figures.
Some advice if you try it: Make sure all your angles are exact. A little slop in each small block produces a lot of slop in the assembled puzzle. I glue the blocks together with cyanoacrylate and finish with teak oil.
Mikeske
Washington State
I am back on the mower deck for the JD 2305 today as the wife had the social worker in to check on her dementia so I had limited time and I had to be present. She is getting the home health aide for another year so that helps. I went back on the mower deck as I found the grass defector and rod and spring. I got that put on and found I missing a 5/16ths wave washer, I stop at Fastenal tomorrow and get the wave washer as mother Deere wanted $5.00 for 75 cent washer. I went to the Deere dealer today and picked up a pair of gage wheels as the 2 of the 4 were worn out and they were badly wallowed out inside. I also had one of the gage wheel holder bent so a little heat, a vise and so hammering straightened that one all out. After all that I greased the all the gage wheels until I saw grease coming out the near side and put the small caps back on. On the way home I stopped and picked up so GL5 75/90 weight gear oil and did a drain and fill on the gearbox. Now the deck is truly finished as far as I am going with it.IMG_1362.jpegIMG_1360.jpeg
DGersic
DeKalb, IL
Got all of the trim around the new door cut and installed. Lock set installed, too. Needs caulk and paint still, but done for now.
Demo of the old rotted trim on the overhead door.
My Grainger order arrived, so I cleaned up the wiper transmission parts, and assembled the press fit with some of this 660. Waiting for it to cure so I can reassemble.
Spent a while setting up the table saw to cut the drip edge piece (9’ rip on a 20* angle, 1x4 PVC) I need for the garage door trim. The rest is all easy straight square or 45* cuts.
There’s a lot of cleaning and flinging needed. Pile of debris in the driveway needs to be cleaned up. I’ll get to that after I cut all of the remaining pieces.
oldman_pottering
Tinonee, NSW Australia
thanks very much
rharman
SoCal
I'd like to see these planter boxes....
rharman
SoCal
There is a LOT to be said for you making it instead of doing an Amazon purchase.
I'm sure she'll treasure this - good thoughts every time she uses it.
oldman_pottering
I finally got around to doing some organisation, for a long time now I have been using the French cleat system and as such my shed has become cluttered with tool holders that have been repurposed, modified etc and now I have all sorts of bits and pieces all around the place, this weekend gone I made this drawer with 2 small trays mounted inside it that slide out of the way to access larger things underneath, I still have to do some final organising but already things seem less cluttered and easier to find
No photos because still the damn thing gives me troubles, although I happened to upload a couple of test photos earlier :mad:
Edit : see below, apparently I can add photos if I use my phone to take the snap while making the post, it wont work if i try to use a photo that I have stored
Prospecter
Maine
New tools, and new knowledge. . . priceless.
cody1325
Southwest Virginia
Welp, found out why my ratchet drawer wouldn't close well.
Pretty much all of this was stuck behind the drawer somehow.
Some of the more i
The garage toolbox was, originally, my Granddad's work toolbox before the current car garage was built in the '90s. He kept the diagrams to a lot of stuff he had to work on in it.
Wiring diagram for an Owens Manufacturing (compaany got bought out YEARS ago) belt starter.
Old Chapman catalog.
I swear by their products. Granddad bought several kits, and kept them everywhere. I'm currently in the process of replacing the soft packs for hard cases, and adding things like Torx.
ODIS
Looks like you have a nice collection of cars ! I could cry when I think of the cars and bikes I let go in my misspent youth
Thank you. Sold one of the collection cars to a fellow here on GJ, but, it moved on to others...... Not what I was expecting. Try to keep all of them now and that is a bit of a problem with storage. Thanks for your post.
