Outside garage light has 110V but bulb does not light
bw77
Upstate NY
Run of 4 outdoor lights, all work except the first light in the run.
I measure 110 volts between the center contact and the threaded part.
Tried known good bulbs, they do not light.
I cleaned the center contact with sandpaper, it's shiny.
Fixture is 50 years old.
Is this just a bad fixture that needs to be replaced?
bw77
Upstate NY
I need a new lamp holder if I can find it.
The connection to the black wire did not look good, I pulled it off by hand.
sparky 1971
Central Iowa
The easiest and cheapest thing to do is buy a floodlight lampholder and take the socket out. You will probably have to recycle the existing bracket.
bw77
Upstate NY
The mounting bracket is held on by a screw.
PCustoms
VT
Home Depot used to sell sockets, either by the fans/pendant lights or over by the outlets, I can't remember. Amazon probably has them too
bw77
Upstate NY
I found one on Amazon that has a detachable mounting bracket.
Leviton 8052-1. Arrives Tuesday.
RPH
Michigan Thumb
Try this.
Turn power off to socket, remove bulb. The center contact needs to be pulled up away from the base towards the bulb base. If that doesn't work, Tuesday will.
bw77
Upstate NY
Try this.
I tried that, no change.
bw77
Upstate NY
The new bulb holder fixed it. I think it failed, in large part, due to moisture getting inside
the fixture. All 3 panes were missing.
I got a piece of plexiglas and I cut 3 new panes to keep out the weather.
Good as new.
