- Joined
- Nov 4, 2017
- Messages
- 10,461
I may fix it up. It's pretty functional as is but definately could use a resto
Any pics with cover off?
Wish I knew, did they look like these?I saw an older Kennedy 520 at an estate sale Thursday. It was in very good condition, and had a few random, but not valuable, machinist items in the drawers. They were asking $350.00 for it, so I passed.
The interesting thing about it was that the drawer handles were not plastic. They were very similar to the plastic ones, but were made of brass. The "face" surface was a concave. I checked the mounting method, thinking they would use blind screws, but they had the split rivets like the older plastic handles.
What years of production would this indicate?
For a while back in the early part of the millenium, someone was selling homemade handles for Kennedy tool boxes, but I don't recall how they attached.The face of these pulls was concave, with the edges pretty sharp. By concave, think of the pull having a ball end mill run from end to end the long way. '
These were attached with the split rivet like the first generation of plastic pulls. They had the two nubs for alignment just like the plastic pulls.
Some of the drawers are installed wrong? keep you from accumulating **** in those drawers?some of the drawers have slides on the top edge and some have
them on the bottom! all the other (4) kennedy boxes i have all are on the bottom. anyone know
whats going on here?
that would work as far as the box goes..but it would just accumulate elsewhere!Some of the drawers are installed wrong? keep you from accumulating **** in those drawers?
But in all seriousness, I have no idea, but could not resist.
Govt, without any doubt, probably Air Force, and that "A/1C" before the name is probably the PO's rank, Airman 1st Class. Early 60s.govt or utilities contract???
Just at a glance, looks like @Private Lugnutz and my ASCO, Art Steel Co, seen way up thread. Not sure about the slides, but that huge hasp on top. Wander about from here.Not mine. Never seen one before. Kennedy? Never seen those exact drawer pull either.
Why do you post photobucket pics? Can't really see past the advertising.
Options were not all that limited back then--I've used Flickr since they started--and PB was always the bottom of the bucket. Post Image is a close second.That post was made fifteen years ago!
Options were limited in 2009 and they did not have the watermark, originally.
Picked up this KR-56 last summer, FBM find for $20. Incredible shape considering the age and use at the Ford Engine plant here in Cleveland. Somebody took care of this..
Timm, How tall is the bottom of the box to the bottom of the tray? I may now have an Eagle oiler that fits this size box:
Just use 0000 steel wool on the drawer pulls & you'll be good to go.Picked these two up off Craigslist.
Really happy with the condition on the RemLine even though it is missing the lock entirely and I think the hasp is a (poor) replacement. Mechanically everything is square and functions well. Cosmetically, there is some light surface rust on the bottom and inside the box which I cleaned up and wiped down with CorrosionX to put a stop to that. I lubed up the drawer slides while I had it apart and they are moving great. Otherwise I like the "patina" and will use it more or less as-is. I'd like to hear some ideas on cleaning up the drawer pulls. Right now the plan is to go at them with some fine steel wool and WD40 or similar.
The Powr Kraft is a lot rougher and I will need to do some amount of "refurb" before I use it. The box is bent at the front edge which jams the bottom drawer up, the top of the box is somehow slightly out of square so the lid doesn't close without some jimmying. Also, the corrosion on the lid definitely needs to be addressed. Once I can get the structure problems and corrosion cleaned up I'll strip this one down and repaint. Would appreciate any tips for this one.
I have had fantastic success with steel wool and wd40 !Just use 0000 steel wool on the drawer pulls & you'll be good to go.
